cfi(at)conwaycorp.net Guest
Posted: Sat Feb 18, 2006 7:50 am Post subject: KLN35A Pin/Installation Diagram |
Does anybody have a pinout guide or installation diagram for the Bendix/King (Honeywell) KLN35A GPS? Bob does not have one on his website. I want to wire-up a RS232 port so I can upload database updates. I don't have a panel mount plug the factory typically provides with the unit so I want to roll my own.
Michael H.
jlbaker(at)telepath.com Guest
Posted: Sat Feb 18, 2006 12:50 pm Post subject: KLN35A Pin/Installation Diagram |
Quote: | Does anybody have a pinout guide or installation diagram for the
on his
Quote: | website. I want to wire-up a RS232 port so I can upload database
Attached is a copy of the sheet they sent to me for my KLN90. Has
the 135A on it as well.....Here ya go!
Jim Baker
580.788.2779
'71 SV, 492TC
Elmore City, OK
The following section of this message contains a file attachment
prepared for transmission using the Internet MIME message format.
If you are using Pegasus Mail, or any other MIME-compliant system,
you should be able to save it or view it from within your mailer.
If you cannot, please ask your system administrator for assistance.
---- File information -----------
File: Gps Dataloader cable.tif
Date: 11 Aug 2004, 22:12
Type: Unknown
Mr. Baker,
The jack that we use is provided in the installation kit for the KLN 90's. The part number for the Nexus jack is
033-00230-0000. It is a Nexus jack, like what is used in the military style microphones. Our cable we offer has a
Nexus plug on one end and a 9 pin serial connector on the other. The part number of the cable is 050-03213-0000.
Attached is the drawing for the cable and jack.
The cable can be ordered from Wingman Services at 800-247-0230.
Posted: Sat Feb 18, 2006 1:19 pm Post subject: KLN35A Pin/Installation Diagram |
Thanks for the diagram Jim! It's very helpful. ...now the plot thickens
with two questions from the village idiot:
1.) Your diagram shows the KLN35A with a "P1" connector. I believe P1
connector has pins 1-22 on one row and pins A-Z on the other. I believe my
unit has a P4001 connector with pins 1-15 on one row and pins A-S on the
other. Are my assumptions are correct and if so, are you aware of a similar
drawing showing the KLN35A with a P4001 connector?
2.) How are the alphabetic rows on the connectors arranged since they don't
line up with their order from their numbered counterparts? For example, on
the P1, why are pins 22 and Z adjacent instead of 22 and V? On the P4001,
pins 15 and S are adjacent instead of 15 and O? Make sense?
Michael H.
Posted: Sat Feb 18, 2006 3:49 pm Post subject: KLN35A Pin/Installation Diagram |
Thanks for the suggestions Jim. Unfortunately, I was not able to find any information about the pin layouts on the LoneStar Aviation site, however; they do have a nifty product.
I checked out the pin layouts at http://www.aeroelectric.com/Installation_Data/KLX135.pdf. It appears the KLX 135 uses both the P1 and P4001 connectors and the P4001 pins K, H, and J do not correspond to the data loader RS232 OUT, ground and RS232 IN respectively. The dataloader pins are on the P1 connector which is non-existent on the KLN 35A. The difference between my unit and the KLX 135 is that the KLX 135 has a built in Comm radio, where my unit is straight VFR GPS unit without Comm, hence; fewer connectors are provided.
The P4001 pin layout for the my unit continues to be a mystery....
Posted: Tue Feb 28, 2006 5:12 pm Post subject: KLN35A Pin/Installation Diagram |
