AirMike
Posted: Sun May 18, 2008 2:46 pm Post subject: Marker Beacon |
Looking for some guidance about putting the MB antenna in the wing tip.
Has anyone done this and how are the results as far as reception.
Since it is basically looking down this would appear to be a no brainer.
Appreciate any comments.
_________________ See you OSH '18
Q/B - sold. |
carl.froehlich(at)cox.net Guest
Posted: Sun May 18, 2008 4:06 pm Post subject: Marker Beacon |
The Marker Beacon radiates straight up at relatively high power. A simple
quarter wavelength of wire in the wingtip or bottom of the cowl should work
well.
A quarter wave antenna at 75Mhz should be about 37.4 inches. If you make it
with a fat wire or wide metal strip it would end up slightly shorter. For
this single frequency application there are no advantages to a wide metal
strip over a single wire.
The simplest thing to do is to run a coax line to a double female bulkhead
BNC connector on the end wing rib (wingtip antenna) or firewall (cowl
antenna). From this you can make the connection to the antenna wire using
another male BNC connector. Leave some slack so you can remove the
connector and hot glue or glass in the rest of the antenna wire. If you
have an old piece of coax laying around you can fit a male BNC to it, then
remove the outer jacket and shield wire from about a half inch from the BNC
connector, leave the center wire as is (with the insulation on), cut the
wire so the total length is 37 1/2".
If mounting in the wing tip try to keep it away from other wiring and as far
from the wing rib as possible.
Carl Froehlich
RV-8A (400 hrs)
RV-10 (flaps)
dlm46007(at)cox.net Guest
Posted: Sun May 18, 2008 4:28 pm Post subject: Marker Beacon |
May be a wrong question but why is anyone thinking of installing a MB
receiver. Any IFR GPS/EFIS identifies passing the OM. When over the final
approach fix which is co=located with a MB, the OM flashes on the EFIS. Same
question for ADF except for perhaps outside the USA. Here ADFs/NDBs and MB
seem to be last century's technology.
billderou(at)yahoo.com Guest
Posted: Sun May 18, 2008 5:03 pm Post subject: Marker Beacon |
We have two RV-10's using the same scheme as Carl wrote and it works well. There is a lot of power coming up from the ground so a simple wire is sufficient. If you plan to install a Bob Archer wingtip antenna today or add a backup NAV antenna in the future suggest you glass in the wire antenna on the upper side of the wingtip. If you glass it on the bottom the Bob Archer antenna will not work properly.
Bill DeRouchey
N939SB, flying
Carl Froehlich <carl.froehlich(at)cox.net> wrote:
[quote]--> RV10-List message posted by: "Carl Froehlich"
well.
Carl [quote][b]
AirMike
Posted: Sun May 18, 2008 6:21 pm Post subject: Marker Beacon |
Thank you for the information Carl. I also received a call which advised me that the MB in wingtip would work with a 18"x 6" wide base plate on which the MB antenna (Comant CI-102) would be mounted as close to the bottom of the wing tip as possible. This would give me a mounting plate as well as the "ground plane". I am not that knowledgeable in this area so any help is appreciated.
I am essentially a VFR pilot but I wanted my plane certified as Day/Nite VFR/IFR so I have an SL30 Nav/Com and a Garmin 340 audio panel. My GPS is a Garmin 496. I figure that I saved about 6K on my panel over having a GNS430 plus on the 496 I get weather and Zaon traffic avoidance. Seems to me the best bang for the buck. My AFS3500 apparently displays the GS but not the MB.
Any further comments appreciated.
| Panel AFS3500, GPS496, SL30, 340 |
1.49 MB |
588 Time(s) |
Q/B - sold. |
Posted: Mon May 19, 2008 1:42 am Post subject: Marker Beacon |
If you are using an external MB antenna, then why not just mount it on
the bottom skin of the wing with a doubler? For that matter, you
could just put it near the wing root and save the cost and weight of
the additional coax. I don't see any need to go to the trouble of
putting a ground plane in the wingtip when you can just use the wing
itself. It will also make the wingtip a little easier to take off
because there will be one less connection. I have used the wire in
the wingtip with a BNC connector on it. Haven't actually tested it,
but the common feeling I have seen in my reading is that a coat hangar
would pickup the signal just fine, so bonding a wire in the wingtip
should work fine. I got this from Bob Archer.
Jesse Saint
Saint Aviation, Inc.
jesse(at)saintaviation.com
Cell: 352-427-0285
Fax: 815-377-3694
On May 18, 2008, at 10:21 PM, AirMike wrote:
OSH '08 or Bust (busted) be there in "09
Q/B Kit - exited cabin top/door purgatory
http://forums.matronics.com/viewtopic.php?p=183752#183752
http://forums.matronics.com//files/a_panel_327.jpg
wcurtis(at)nerv10.com Guest
Posted: Mon May 19, 2008 5:55 am Post subject: Marker Beacon |
A Marker Beacon receiver is included in most audio panels so why not wire it up for the pure ILS/LOC approaches. How is that EFIS determining it is passing the OM--by GPS position? Not exactly legal for an ILS/LOC approach. The MB is an integral component of an ILS/LOC approach--even though it may be superfluous in the age of GPS overlay.
The comparison to an ADF is not valid since for an ADF you would have to actually install an additional component--in addition to the antenna.
William
http://nerv10.com/wcurtis/
dmaib@me.com
Posted: Mon May 19, 2008 7:34 am Post subject: Marker Beacon |
I thought that an IFR approved GPS could legally identify marker beacons and NDB's. Is that not correct?
David Maib
40559
buried in fiberglass dust
On Monday, May 19, 2008, at 09:02AM, "William Curtis" <wcurtis(at)nerv10.com> wrote:
William
_________________ David Maib
RV-10 #40559
New Smyrna Beach, FL |
Posted: Mon May 19, 2008 8:38 am Post subject: Marker Beacon |
I'll have to check but I believe the substitution is only allowed for NBD and DME not MB--but again this is splitting hairs.
William
n212pj(at)gmail.com Guest
Posted: Mon May 19, 2008 8:59 am Post subject: Marker Beacon |
If you are equipped to fly ILS/LOC approaches, and you intend to fly such
when you can, that is, when you feel that is your best or only option, then
put the MB in. In some cases it may be your only option. Should you lose
that GPS, you're all set. Easy enough to do, sounds like.
John J
drfred(at)suddenlinkmail. Guest
Posted: Mon May 19, 2008 9:45 am Post subject: Marker Beacon |
Any theoretical reason why the top vs the bottom of the wingtip? When
I took my EAA class about year and half ago, they showed the
installation in the bottom half of the wingtip?
Fred.
Bill DeRouchey wrote:
| Quote: | We have two RV-10's using the same scheme as Carl wrote and it works
Bill DeRouchey
N939SB, flying
simple
should work
well.
you make it
shorter. For
wide metal
bulkhead
wire using
If you
it, then
from the BNC
cut the
and as far
Carl
sam.marlow
Posted: Mon May 19, 2008 10:10 am Post subject: Marker Beacon |
Just glassed mine in the wingtip, works great!
Sam
http://forums.matronics.com/viewtopic.php?p=183725#183725
Kellym
Posted: Mon May 19, 2008 4:12 pm Post subject: Marker Beacon |
Marker beacons have been on the phase out plan by the FAA for some time.
I've been surprised a few times when a beacon actually sounded off, but
it has been awhile. No middle marker that I know of is required for an
ILS anymore as DH is used instead, and very few use outer markers
anymore, and those are usually named, published fixes in GPS databases.
Otherwise have approach control give you a radar fix for the FAF.
John J
KCHD |
Posted: Mon May 19, 2008 5:10 pm Post subject: Marker Beacon |
True enough. But they do exist and are useful, even as verification, until
totally eliminated. Brings up a point about going with the SL40 vs the
SL30. I'd go with the 30 simply because it gives you the VOR's as a useful
tool. Some say not to since they, too, are supposedly on the way out. Just
depends on how many revs back you want to go. You have to know how to fly
and utilize what's in your panel.
Kelly McMullen
Posted: Mon May 19, 2008 5:28 pm Post subject: Marker Beacon |
No disagreement, since I still have working ADF, MB and Loran in my current panel. Don't think I will move any of them to new panel when I get there, but probably a couple years off to decide.
On Mon, May 19, 2008 at 9:05 PM, John Jessen <n212pj(at)gmail.com (n212pj(at)gmail.com)> wrote:
[quote] --> RV10-List message posted by: John Jessen <n212pj(at)gmail.com (n212pj(at)gmail.com)>
A&P/IA, EAA Tech Counselor
KCHD |
