Elevator travel vs sesnsitivity
rsteele(at)rjsit.com
PostPosted: Thu May 15, 2008 3:35 pm    Post subject: Elevator travel vs sesnsitivity Reply with quote
I've unfortunately never flown the 601xl, but one of the things I
keep reading is that it's very sensitive in pitch. Since it's now
recommended to limit elevator travel, would it be possible or
desirable to change the control geometry a bit do so there ratio of
stick movement to surface move is higher? It seems like this would
mitigate the sensitivity a bit.
Ron
larry(at)macsmachine.com
PostPosted: Thu May 15, 2008 3:53 pm    Post subject: Elevator travel vs sesnsitivity Reply with quote
The elevator authority is there, but it's not excessive. It's part of
what makes the landings fun because you can hold off the nose gear and
grease it.
I wouldn't change a thing. Those that complain about it either haven't
flown or have not learned to fly the aircraft. It's the slower speeds
that the
elevator is a best feature of the Zenith.
Ronald Steele wrote:
I've unfortunately never flown the 601xl, but one of the things I keep
Ron
ibution
planecrazydld(at)yahoo.co
PostPosted: Thu May 15, 2008 4:48 pm    Post subject: Elevator travel vs sesnsitivity Reply with quote
some of the sensitivity in the pitch control system is simply the low stick force per G in the XL.
While you would have to give up the electric trim to do so, it would be a very simple matter to change the system so that the tab is both trim and anti-servo. The anti servo feature is a very common method used to augment stick force and centering forces.
Ronald Steele <rsteele(at)rjsit.com> wrote:[quote] --> Zenith601-List message posted by: Ronald Steele
stick movement to surface move is higher? It seems like this would [quote][b]
Martin Pohl
PostPosted: Fri May 16, 2008 12:31 am    Post subject: Re: Elevator travel vs sesnsitivity Reply with quote
Hi everybody
I have flown an XL only once, but was very happy with the accurate and direct sensitivity of the elevator. It is rather like flying a glider and not comparable to the "sluggishness" of a C-172. But if you are or get used to it, it is really great fun and by no means uncomfortable.
My XL elevator has a Ray Allen servo trim, but I will install this add-on-module that slows the movement of the servo (also provided by Ray Allen). The trim servo was a little bit too sensitive in my opinion.
I am really looking forward to getting my XL in the air. I fly Katanas (Diamond), C-172 and A-330/340s regularly at the moment, and the XL is somewhat comparable to both the Katana and the Airbus (and no, it's not like flying a C-172), as its control authority is enjoyably direct!
Cheers Martin
Martin Pohl
Zodiac XL QBK
8645 Jona, Switzerland
http://www.pohltec.ch/ZodiacXL/Main.html
