Settting the correct Spacing (Gap) between VS Top Rib and Ru
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> RV9-List
gareywittich2000(at)yahoo
PostPosted: Fri May 09, 2008 8:27 pm    Post subject: Settting the correct Spacing (Gap) between VS Top Rib and Ru Reply with quote
Greetings:
The construction of my RV8A (RV7 and RV9 are the
same) the Rudders Top Rib swings OVER the top Rib of
the VS. There is suppose to be a "Gap" between the
two Ribs so that there is no interference (rubbing of
them together) as the Rudder is moved.
My question is - how do you set this Gap up ???
It seems to me that the Rod End Bearings on the Rudder
Spar need to be screwed into the Rudder Spar the "
Final" distance so that the Gap can be set up properly
BEFORE the Rudder Skin is finally riveted to the
Rudders Top Rib (R703) which sets this Gap. My
understanding the dimensions for screwing the Rod End
Bearings as shown on the Drawing 7 is only
"approximate" and needs to be fined tuned later = this
could change this Gap distance.
Or if one marks a center-line on the flange of the
Rudders Top Rib and aligns the pre-punched holes in
the Rudder Skin directly over the "center of this
line", does it Guarantee automatic clearance and a
constant Gap distance when the Rod End bearings are
set to their "Final" screwed-in distance ??????
The Orndorff Tapes show the Rod End bearings installed
in the Rudder Spar (no Rod End Bearing dimensions
given) and mounted to the VS and the Gap set by
bending Up the Rudders Top Rib (R703) to parallel the
VS Top Rib. Maybe I am missing something. So what
worked for you - set the Rod End Bearings "approx" or
align the pre-punched holes in the Rudder Skin
directly over the marked center-line on the Rudders
Top Rib flange and THEN rivet the Rudder Skin ????
Once the Rudder Skin is riveted to the Rudders Top
Rib, the Rudders Top Rib is fixed and can NOT be
readjusted to get the "correct Gap" later.
Appreciate your help, Garey Wittich
Be a better friend, newshound, and
know-it-all with Yahoo! Mobile. Try it now. http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
- The Matronics RV9-List Email Forum -
http://www.matronics.com/Navigator?RV9-List
rv9flyer(at)sbcglobal.net
PostPosted: Sun May 11, 2008 1:05 am    Post subject: Settting the correct Spacing (Gap) between VS Top Rib and Ru Reply with quote
Garey Wittich <gareywittich2000(at)yahoo.com> wrote: [quote] --> RV9-List message posted by: Garey Wittich
Greetings:
Garey,
It has been a while since I constructed my VS and Rudder, but as I recall I did nothing special. I think I was probably young and dumb into the project, and just trusted that all would turn out ok. I built both pieces independant of the other, and fitted them together at the very end. I ended up with acceptable spacing, but did find that the bearing distance from the rear VS spar is critical if you want to prevent binding. This also sets the angle between the VS and the rudder, and thus the spacing for the overhang. When I do the final assembly vs the test fit, I may have to do some filing, but so far I remember having equal spacing between the two.
Good luck!!!
Greg Richardson
RV9A fuse
PostPosted: Sun May 11, 2008 2:09 am    Post subject: Settting the correct Spacing (Gap) between VS Top Rib and Ru Reply with quote
Garey Wittich <gareywittich2000(at)yahoo.com> wrote: [quote] The Orndorff Tapes show the Rod End bearings installed
Garey,
I just re read your post, and saw the second part of the question there. That set me to looking, and I found out what you are saying. I was able to locate, from my print 6pp, that the distance from spar to spar, measured at the top of the rudder just below the counterbalance, is supposed to be 2". At the root, which I took to be the bottom of the rudder, the spar to spar distance should be set at 2 1/2". On the 9A, the pre-set bearing distances are not in the instructions, or on the prints either. I realized that I purchased my $50 set of prepurchase full prints and instructions at about that time, and was delving through them. Yours may be different, but if you read ahead to where the empenage is mounted to the fuselage, on my page 8-15 and 8-16, it states:
"Thread the rod end bearings and jam nuts into the rudder spar. Measure from the center of the pivot bolt hole, to the forward face of the rudder spar. As a starting point, you may use these measurements: Top 0.80" Middle 0.990456789" (author states, and is why I remembered seeing it) OK get sloppy and call it 1.0" Bottom 1.00" (to face of spar doubler). Adjust these measurements as neccessary to make the rudder swing without binding."
I think when I used those measurements, I ended up adjusting the center bearing by 1/2 turn to prevent binding. Hope this helps you.
Good luck,
Greg Richardson
RV9A (fuselage)
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> RV9-List All times are GMT - 8 Hours
