		1rv4
				 Posted: Fri May 09, 2008 7:09 am    Post subject: Gearleg fairings? |
				Hey Fellas
           I've been flying my Harmon Rocket for a grand total of 5 hours now
 and all was going well until I put on the gearleg fairings and wheelpants.
 When I first flew it without the fibreglass bits she would pull to the left
 ever so slightly at full throttle and require very light right rudder to
 keep the ball centered.
   Now with the fairings and pants installed the ball is to the right about 3
 ball widths and requires quite a lot of right rudder pressure to keep the
 ball centered..  I removed the wheelpants last night and flew it like that
 with no improvement, so I guess I have the gearleg fairings creating
 drag.Now my question is would it be the port (left) fairing creating the
 drag and the right one would be OK. or could they both be out. My theory is
 that they are mini airfoils and both could be creating pressure and trying
 to turn the ship around the center point. They look to be in line if you
 just eyeball them, and I was very careful (I thought)  in aligning them with
 the airflow when installed, but the best laid plans and all that. I sure
 don't want to make another set of intersection fairings.Anyone have this
 problem? any suggested fixes?
               Chris F
  |  | - The Matronics Rocket-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  http://www.matronics.com/Navigator?Rocket-List |
		n395v
				 Posted: Sat May 10, 2008 4:37 am    Post subject: Re: Gearleg fairings? |
				Jack the plane up so that the wheels are off the ground and the gear drift inward and see how they look.
  _________________ Milt |
		Im7shannon(at)aol.com Guest
				 Posted: Sun May 11, 2008 10:37 am    Post subject: Gearleg fairings? |
				If it is not making it slower, it would be easier to install a trim tab on  the rudder than make new intersect fairings.
  I guess I am just saying that because I am painting mine right now and I  don't want to do any of this over after weeks of sanding!
  Kevin Shannon
  HR II
   	  | Quote: | 	 		  Hey    Fellas
                  Chris F
 Wondering what's for Dinner Tonight? Get new twists on family favorites at AOL Food.
		jrstone(at)insightbb.com Guest
				 Posted: Sun May 11, 2008 1:11 pm    Post subject: Gearleg fairings? |
				3 ball widths is beyond reasonable in my book.  Remember, this equates  to drag whether you trim it with rudder trim tab or not.  I would consider  all that gas you will waste over the life of the airplane and really try to  determine the cause.  I had a similar yaw from the fairings but mine was  half a ball so I added a trim tab.
  Good luck,
  Jim Stone
  HRII 95 hrs
  [quote]   ---
		nico(at)cybersuperstore.c Guest
				 Posted: Sun May 11, 2008 2:33 pm    Post subject: Gearleg fairings? |
				I'd say a three-balls  width points to a serious rigging problem. Consider the amount of surface your  rudder has to protrude into the airstream to produce that kind of yaw and you  would appreciate the drag. If you add to that equation the arm of the rudder to  the COG compared to the (much shorter) arm of the gear legs to the COG, it would  illuminate the seriousness of the problem. I'd be surprised if it is the  fairings but your account of the problem suggests that it is. Did anything else  happen to the control surfaces since the installation?
    From: owner-rocket-list-server(at)matronics.com  [mailto:owner-rocket-list-server(at)matronics.com] On Behalf Of Jim  Stone
 Sent: Sunday, May 11, 2008 2:09 PM
 To:  rocket-list(at)matronics.com
 Subject: Re: Gearleg  fairings?
  Good luck,
  Jim Stone
  HRII 95 hrs
  [quote]   ---
