LED position lights + strobe
sarg314(at)comcast.net
PostPosted: Fri Feb 24, 2006 11:12 pm    Post subject: LED position lights + strobe Reply with quote
Some months ago I saw a small outfit selling small LED position lights
which also accomodated a strobe light and would fit in the van's
recessed (enclosed) wingtips. I thought I saved a reference to it, but
can't find it. Does this ring a bell with any one?
Tom Sargent
engine
n395v
PostPosted: Sat Feb 25, 2006 7:11 am    Post subject: Re: LED position lights + strobe Reply with quote
http://www.creativair.com/cva/light_kits_guide.php?osCsid=bb135451797b0a698612f9e5c7fc48f8
Is this the place?
Milt
Deems Davis
PostPosted: Sat Feb 25, 2006 7:33 am    Post subject: LED position lights + strobe Reply with quote
I just installed these, http://deemsrv10.com/decisions.html (scroll down
to LED & Strobe write-up). They are made by an RV7 builder named Jeff
Bordelon. The links are in the write-up
Deems
Tom Sargent
engine
Dennis Glaeser
PostPosted: Sat Feb 25, 2006 8:06 pm    Post subject: LED position lights + strobe Reply with quote
Try: www.thorllc.net
Dennis Glaeser
7A Fuselage
Tom Sargent
engine
Phil White
PostPosted: Sat Feb 25, 2006 8:15 pm    Post subject: LED position lights + strobe Reply with quote
Tom: www.GS-Air.com may be what you were referring to. I installed a
set of their LED lites w/strobes in the tips of my RV-10 wings about a
year ago. They have updated their product line recently with brighter
LED's that they state will better meet FAR-23 illumination rules.
Phil (RV-10 fuse) in IL
Subject: LED position lights + strobe
Tom Sargent
RV-10 #40220 in Downers Grove, IL
(airframe done exc. gear fairings)
enewton57(at)cableone.net
PostPosted: Sun Feb 26, 2006 7:33 am    Post subject: LED position lights + strobe Reply with quote
Could be this one:
http://www.creativair.com/cva/product_info.php?cPath=3D21&products_id=3D44
Eric
william.p.dube(at)noaa.go
PostPosted: Mon Feb 27, 2006 5:02 pm    Post subject: LED position lights + strobe Reply with quote
I designed these particular LED position lights and sell the kits. If
you have any questions, feel free to ask.
Mike shipper did a very nice write up when he built a pair of my lights.
Mike is a bit more of a perfectionist than most, so he put in about
double the time it takes the typical person to build the kit. Taking
these terrific pictures and doing this write-up also probably counted in
the time. (Most folks take about 4 hours to build the kit. I do them in
less than an hour, but I have a little bit of practice at this point.)
http://www.my9a.com/lights.asp
>>Caution - Blatant self promotion about to occur<<<
These LED position light kits cost less than $150 per pair. This is
cheaper than the standard incandescent lights.
Theses lights are the only ones on the market that are available as a
kit. (Most folks that are building a kit airplane seem to like building
kit position lights.)
The lights put out more light than required by the FAA in all
directions. I even tell you how to measure the light output yourself in
the instructions.
The LEDs will outlast the airplane.
I took a "belt and suspenders" approach in the design. They have 23
separate current regulated circuits. You can drill a few holes in each
light and they won't go dark. They stay the same brightness from 10
volts up to 30 volts input.
They only draw half an amp for the pair of lights. They are much,
much lighter than incandescent position lights.
Bill Dube' <LED(at)Killacycle.com>
Eric Newton wrote:
Could be this one:
Eric
