Check lists, Was: Master switch warni
ykibuess(at)bluewin.ch
PostPosted: Sun Jan 08, 2006 7:53 am    Post subject: Check lists, Was: Master switch warni Reply with quote
The buzzer idea sounds great! Lights and other devices fed by the always
hot battery bus will empty the battery one day if that bus is not
supervised by an intelligent warning system. Any specialist in
electronics out there who is able and willing to invent and build such a
warning (buzzer) system?
Alfred
-----Ursprngliche Nachricht-----
Von: owner-aeroelectric-list-server(at)matronics.com
[mailto:owner-aeroelectric-list-server(at)matronics.com] Im Auftrag von Ken
Gesendet: Samstag, 7. Januar 2006 18:50
An: aeroelectric-list(at)matronics.com.AeroElectric-List
Betreff: Re: AeroElectric-List: Check lists, Was: Master switch warning,
AeroElectric-List
A universal solution might be a buzzer that detects when more than a few
ma of current is flowing out of the battery. I'll think about it but I
don't think I know a simple way to do that such that it draws no standby
current, and doesn't add failure points to the original aircraft wiring.
Ken
BigD(at)DaveMorris.com
PostPosted: Sun Jan 08, 2006 8:12 am    Post subject: Check lists, Was: Master switch warni Reply with quote
I'll bet you can find schematics for those in Popular Electronics going
back to the mid 1930's.
Dave Morris
At 09:53 AM 1/8/2006, you wrote:
<ykibuess(at)bluewin.ch>
Alfred
AeroElectric-List
Ken
