Flying an RV8
tom.gregorski(at)juno.com
PostPosted: Sat Apr 19, 2008 5:08 am    Post subject: Flying an RV8 Reply with quote
I just finished my RV8 and it had its first flight by an experienced RV driver. I took some lessons in a RV7, but I am not comfortable flying it and scared to fly mine. I am having a hard time getting good landings. I am used to flaring over the runway, but he teaches flying it to about a foot over the runway and then bleeding off the airspeed until it quits flying. He does this because of the abrupt stalls and does not want it to happen too high above the runway. Is this the way others fly RVs. I would like some other opinions. I did stall the RV7 and the stall is very rapid without any warning. Thanks, Tom
_____________________________________________________________
Succeed in Your Weight Loss Goals. Easiest Protein Diet. Click Now!
http://thirdpartyoffers.juno.com/TGL2121/fc/Ioyw6i3nsBcTXbt66paa5AbdxSBwZiXthpzfzrEWHlSjlTMSLBJIAc/
rice737(at)msn.com
PostPosted: Sat Apr 19, 2008 1:58 pm    Post subject: Flying an RV8 Reply with quote
Hey Tom,
There are many different techniques to landing any airplane. I find that I use the same/similar technique on every aircraft I fly be it an RV to Boeing. The method you mentioned is good for learning where the wheels are on the first couple of landings, but then I would transition to landing your plane just as you would land a Cessna. Come down final at stall speed plus about 30 percent, flare and find the ground. Go take a few lessons in a Cub if you can find one, it is more difficult to land than an RV. If you are even a little comfortable in it, you will have no trouble in your 8. I don't think the 8 has an abrupt stall, mine gives me plenty of warning with a shutter of the tail. You will also feel the controls getting a lot lighter.  Go up and stall it a few times, straight ahead and fly it around for a while at stall plus 30 percent and in no time at all, you will not even need and airspeed indicator to know that you are right in the sweet spot.
Good Luck,
Paul
RV8 with 75 hours of fun
Date: Sat, 19 Apr 2008 13:04:41 +0000
To: rv8-list(at)matronics.com
Subject: Flying an RV8
--> RV8-List message posted by: "tom.gregorski(at)juno.com" <tom.gregorski(at)juno.com>
bjudge(at)gmail.com
PostPosted: Sun Apr 20, 2008 4:27 pm    Post subject: Flying an RV8 Reply with quote
I'm got about 230 hrs in my 8 and I almost never do a 3 point. Mine
wheel lands very well and tends to crow hop a lot when doing a 3 pt.
I believe this is because the critical angle of attack is greater than
the 3 pt attitude angle of attack hence it tends to still be flying
with the wheels on the ground. 65 knots seems to be a nice speed for
final, wheel it on, keep it straight and you won't have any trouble.
Bill
N84WJ
rv-8.blogspot.com
On Sun, Apr 20, 2008 at 2:57 AM, RV8-List Digest Server
<rv8-list(at)matronics.com> wrote:
Today's complete RV8-List Digest can also be found in either of the
of the RV8-List Digest and can be viewed with a generic text editor
HTML Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 08-04-19&Archive=RV8
Text Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 08-04-19&Archive=RV8
RV8-List Digest Archive
Total Messages Posted Sat 04/19/08: 2
Today's Message Index:
1. 06:08 AM - Flying an RV8 (tom.gregorski(at)juno.com)
2. 02:58 PM - Re: Flying an RV8 (Paul Rice)
Time: 06:08:59 AM PST US
From: "tom.gregorski(at)juno.com" <tom.gregorski(at)juno.com>
Time: 02:58:06 PM PST US
Subject: RE: Flying an RV8
Hey Tom,
Good Luck,
Paul
RV8 with 75 hours of fun> From: tom.gregorski(at)juno.com> Date: Sat, 19 Apr 2
008 13:04:41 +0000> To: rv8-list(at)matronics.com> Subject: Flying a
orski(at)juno.com>> > I just finished my RV8 and it had its first flight by an
d without any warning. Thanks, Tom> _______________________________________
______________________> Succeed in Your Weight Loss Goals. Easiest Protein
Diet. Click Now!> http://thirdpartyoffers.juno.com/TGL2121/fc/Ioyw6i3nsBcTX
========================> _
