M14-p
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> M14PEngines-List
haavard-iversen(at)c2i.ne
PostPosted: Sun Feb 26, 2006 11:46 pm    Post subject: M14-p Reply with quote
Me and my friend have been opertaing our Yak during wintertime now, operating the engine below 5 degrees Celsius, even down to -5. STarting the engine really hasn´t ben difficult, but have learned that you should not without pre-heating. We have drained for oil every 3 days without a flight, turning 20 blades before priming and another 10.
After the last flight at Saturday, we notice some oil dripping out of the exhaust imediatly after shut down.(maybe a teaspoon  full)
That we didn´t like much! How common is this? May this be a sign of a minor hydraulic lock, with bent engine parts?
Since the cold weather, we also needed to prime some nicks while starting, to get it to fire properly and run. Is there a chance of overpriming causing damage?
Please advise, and from only those serius guys!
Thanx!
Håvard N. Iversen
Televeien 14A
2020 skedsmokorset
mobil: +47 928 93 546
www.yaknorway.com
e-mail: haavard-iversen(at)c2i.net (haavard-iversen(at)c2i.net)
I am using the free version of SPAMfighter for private users.
It has removed 421 spam emails to date.
Paying users do not have this message in their emails.
Try SPAMfighter for free now!
- The Matronics M14PEngines-List Email Forum -
http://www.matronics.com/Navigator?M14PEngines-List
tedwaltman(at)i1ci.com
PostPosted: Mon Feb 27, 2006 5:56 am    Post subject: M14-p Reply with quote
Hello,
Very common to have oil drip from exhaust.  In fact, I see such maybe 98 times out of a hundred.  Absolutely normal.  Sometimes I see quite a bit of oil; sometimes hardly any.
Yes, you can get hydolock from over priming.  I have a manifold drain that I installed off of #4, #5 and #6.  So, in cold weather in particular, I prime the heck out of it, sometimes seeing fuel dripping out of my manifold drain--in which case I know it is fully primed.  As long as you carefully pull the blades through after priming to check for restriction you're Ok.
Ted Waltman
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> M14PEngines-List All times are GMT - 8 Hours
