Odyssey % of charge
rparigor(at)SUFFOLK.LIB.N
PostPosted: Tue Feb 14, 2006 12:27 am    Post subject: Odyssey % of charge Reply with quote
If the charging system is not working does anyone have an approximate % of
remaining capacity versus voltage for a Odyssey PC680 or similar?
What is a safe lower voltage limit one can discharge a PC680 to and not
cause permanent battery damage?
Thx.
Ron Parigoris
alexpeterson(at)earthlink
PostPosted: Tue Feb 14, 2006 4:53 am    Post subject: Odyssey % of charge Reply with quote
approximate % of remaining capacity versus voltage for a
to and not cause permanent battery damage?
Thx.
Ron Parigoris
Go to their website, there is a complete pdf for downloading.
Alex Peterson
RV6-A N66AP 714 hours
Maple Grove, MN
nuckollsr(at)cox.net
PostPosted: Wed Feb 15, 2006 5:12 am    Post subject: Odyssey % of charge Reply with quote
I guessing . . . but when most folks ask this question,
the goal is to deduce some sense of how long the battery
will run certain pieces of equipment given it's present
state of charge.
Keep in mind that voltage versus capacity deductions are
only valid for a battery that is not loaded. Further the
numbers are only approximate and most valid after the
battery has been sitting static (neither loaded nor
charged) for hours.
Finally, any deductions you might make for endurance must
be guided by knowing the battery's present CAPACITY as
well. Knowing the voltage alone is like driving an
unfamiliar vehicle with a gas gage calibrated as
E - quarter - half - three quarters - Full. You have
some sense of percentage of fuel remaining but without
knowing the capacity of the tank, there's no way to
deduce range and present rate of consumption.
Know that ALL lead-acid technologies are 95% used up
at 11 volts for a 12-volt battery. See:
http://www.aeroelectric.com/Pictures/Curves/Capacity_vs_Voltage.gif
This is a curve for a big biz jet battery where we see
that for "light" loads (1 to 2x of capacity), the discharge
voltage has a sharp "knee" that increases the negative
going slope as it crosses 11v/22v line.
This particular battery is capacity rated at CC levels
of discharge i.e., it's a 37 a.h. battery that will give
100% of rated capacity at 74 amps of discharge (typical
for rating bizjet batteries that have a 30 minute emergency
requirement). If one were to discharge this battery like
most of the rest of the industry does (20 hour rate) then
it would probably exhibit a capacity on the order of
50 ampere-hours.
Check out this curve from the datasheet on a Panasonic
33 a.h. battery:
http://www.aeroelectric.com/Pictures/Curves/LA1233_Panasonic.gif
Again, note the shape knee in the curve as it dives
through 11 volts . . . all used up. In this case, the
battery is not specifically rated for emergency power
service in airplanes - it couldn't be called a
33 a.h. device. If we run up the 30-minute line to
11 volts, we find that the battery would have to be
rated as a 26 a.h. device if intended for that kind
of service.
The only way to KNOW how long your battery will perform
certain duties during alternator out operations is to
track the battery's capacity. I.e., load it with the
anticipated endurance loads and see how long it takes
to get down to 11.0 volts. I'm guessing this is the number
you were hoping to deduce with the answer to your original
question. A pure voltage measurement is not a useful
anticipator of performance when the alternator is off
line.
PostPosted: Fri Feb 24, 2006 6:21 am    Post subject: Odyssey % of charge Reply with quote
At 05:30 AM 2/24/2006 -0800, you wrote:
Robert L. Nuckolls, III wrote:
> HERE'S THE POT HOLE - THE 30 MINUTE DISCHARGE CURVE
> OF 26.4 AMPS SAYS THE CAPACITY IS 26.4A X 0.5 HOURS
> OR 13.2 A.H., NOT 26 A.H.
> I SHOULD HAVE CAUGHT THAT . . . A 33 TO 26 REDUCTION
> IN APPARENT CAPACITY FOR A 15X LARGER DISCHARGE
> RATE DIDN'T RAISE THE FLAGS. FOUND IT WHILE ARCHIVING
> THE POST.
Welcome to Peukert's exponent. If you know the capacity at two different
discharge rates you can interpolate or extrapolate the capacity off the
battery at other discharge rates.
Yeah . . . sorta. I'm working on that question along with the
notion that owning one of those super-charge-all smart battery
chargers is a good thing to do to. I'll give you all a forecast
on present findings:
An $80 smart charger and $??$ capacity meter are not well suited
to our ultimate design goals (1) know that the battery is mission
capable every time we walk up to the airplane and (2) have tools
requiring minimum expense and user time/attention to track that
capability. None of the devices I cited above do a very good job
of meeting those goals. An article on alternative hardware proposals
is in the works.
< What is so wonderful about scientific truth...is that >
< the authority which determines whether there can be >
< debate or not does not reside in some fraternity of >
< scientists; nor is it divine. The authority rests >
< with experiment. >
< --Lawrence M. Krauss >
brian
PostPosted: Fri Feb 24, 2006 7:15 am    Post subject: Odyssey % of charge Reply with quote
is in the works.
Having a smart energy monitor is necessary in a system where you will
have irregular charge/discharge cycles and want to know how much is left
in the battery. If you always recharge the battery to full every time,
you can have a much simpler energy monitor that isn't quite so smart.
The biggest issue as I see it is that you need to make sure you don't
overcharge the battery in summer but that you do actually charge the
battery in winter. That implies temperature compensation.
Brian Lloyd 361 Catterline Way
brian-yak at lloyd dot com Folsom, CA 95630
- Antoine de Saint-Exupery
Brian Lloyd
william.p.dube(at)noaa.go
PostPosted: Fri Feb 24, 2006 9:20 am    Post subject: Odyssey % of charge Reply with quote
State-of-charge meters, like the Link-10
<http://www.xantrex.com/web/id/97/p/1/pt/5/product.asp> add up the
amp-hrs in and out (in a fancy manner) to figure the state-of-charge.
If the battery is damaged or worn out, (or the unit loses track of what
has happened lately,) the remaining capacity displayed is incorrect.
The high-tech battery testers like
<http://www.batterymart.com/battery.mv?p=ACC-SB-300> often use the
impedance of the battery to judge its health. If you measure voltage,
current, and temperature, and play them against each other, you can
estimate the state-of-charge and the health of the battery. This is more
what you want for an aircraft instrument. The key is measuring impedance
(along with an estimate of OCV) and comparing it to what had been
measured before under similar conditions.
>> THE POST.
is in the works.
PostPosted: Fri Feb 24, 2006 9:27 am    Post subject: Odyssey % of charge Reply with quote
> is in the works.
in the battery.
Agreed . . . but how does this happen on an airplane and how
often might one expect to encounter it? . . . and are there
less complicated and more positive ways to achieve the desired
mission/maintenance conditions?
Yup.
Agreed . . . and it's not clear that we have really practical
ways to achieve that. The LR-3 from B&C offers a battery temp
sensor option. But it's not clear to me that this option will
produce really meaningful differences in battery performance for
most of our fellow airplane drivers.
brian
PostPosted: Fri Feb 24, 2006 12:48 pm    Post subject: Odyssey % of charge Reply with quote
> in the battery.
Oh, I agree that you don't need a complex energy monitor nor do you need
a fancy charger. OTOH, I have had experience with batteries failing due
to overcharge in hot weather and failing to charge properly in cold weather.
Yup.
I believe that this is one of the key reasons why current crop of
"sealed" AGM aircraft batteries have such a poor service record. Flooded
cell batteries shrug off overcharge by just boiling off excess water
which gets topped off by the owner or mechanic. AGMs build up pressure
in the case and valves open and relieve the pressure, letting the water
go to the atmosphere. The AGM battery, having no excess
electrolyte/water, quickly quits working. I have never had an AGM
battery (Concorde especially) survive longer than two years in a
standard aircraft electrical system.
Brian Lloyd
brian-yak(at)lloyd.com
Brian Lloyd
PostPosted: Sat Feb 25, 2006 2:46 pm    Post subject: Odyssey % of charge Reply with quote
>> in the battery.
> Yup.
It would be interesting to put a battery black-box on those
airplanes. I'm working a design for just such a critter with
one of my associates at RAC. It's a matchbook sized module that
installs in the head-space of an AGM battery. For a period of three
years, it will measure and record battery voltage and temperature
every 10 seconds.
When a battery craps in warranty, the owner recycles the battery
through local channels and sends the 0.5 ounce module back to the factory.
For batteries out of warranty, the owner gets a discount on a
new battery if he returns the black-box along with his order.
I expect this product to yield very revealing data both about
materials and processes used to craft good batteries along with
detailed insight into the battery's experience up and until
the time of failure/replacement.
This is a desperately needed tool for closing the loop in the
consumer/supplier relationship for batteries. So much bad blood
has flowed and much opportunity for improvement lost for lack
of data. The vast majority of discussions/deductions/accusations
about battery life has been floobydust from the customers,
interested observers AND manufacturers. A crapped battery is exceedingly
difficult to deduce life history from a simple teardown inspection.
Nobody is deserving of kudos or cabbages because there are no data
from which understanding can grow.
brian
PostPosted: Sat Feb 25, 2006 3:40 pm    Post subject: Odyssey % of charge Reply with quote
Wow! I haven't heard anyone use the term Floobydust since my days
building analog amps back in the mid '70s.
But I think the battery manufacturers know a lot about how their
batteries live and die. It shouldn't be too hard to understand their
data and apply it to batteries in aircraft.
Brian Lloyd
PostPosted: Sat Feb 25, 2006 6:47 pm    Post subject: Odyssey % of charge Reply with quote
exceedingly
I think that's a Bob Pease original . . . I didn't hear it until
I became an avid reader of his monthly columns probably in the
80's . . . a good term I think for labeling intellectual babble
masquerading as fact.
In the lab, yes. Lightbulbs are the same way. I just finished
a song and dance routine to the FAA hand-cranked organ to subsitute
#327LSV (25,000 hour) lamps for the #327 (4,000 hr) in some places
on our airplanes. Seems customers are seeing a few hundreds of
hours . . . and since the L1011 went into the Everglades a few years
back, crews are forbidden to diddle with lightbulbs in flight, if at
all. So the low-life lamps are a serious regulatory dispatch item
and they're hoping that the better rated lamps will alleviate the
problem. The question not asked and answered was how lamp cycling
affects life and can we REALLY expect a 6x increase in lamp life
with the substitution?
I think we've made the FAA happy but now I'm starting more tests
on my own to do some cycle testing with the two part numbers side-by-side
for relative service life comparisons. I would not be surprised to
discover performance that falls far short of the customer's (and my
boss's expectations). At least I might be able to forewarn them as
opposed to waiting for a followup call from a surprised and unhappy
customer. If we called GE and asked how long their #327 will last in
our airplane, they wouldn't have a clue. You call Enersys or Concord
with the same question, they'd be silly to attempt a considered answer
because there's no data upon which one might consider. Further, they
have no idea how you will use/abuse their product.
I've discussed the battery black-box with a manufacturer who has
heartily endorsed the idea . . . both as a lowered cost warranty
adjustment tool but as a device for getting real numbers about
how their products are treated over LONG periods of time . . . not
in a laboratory or short term flight test program.
