Baclup Battery monitor
mgoodrich(at)tampabay.rr.
PostPosted: Fri Feb 24, 2006 7:50 am    Post subject: Baclup Battery monitor Reply with quote
Hello All,
I am installing a backup battery for a dual EI installation.
I'm looking for a way to monitor w/warning, the voltage and
possibly load on it. Any ideas??
Mitchell Goodrich
VEZE 60P
Tampa,FL
frank.hinde(at)hp.com
PostPosted: Fri Feb 24, 2006 8:24 am    Post subject: Baclup Battery monitor Reply with quote
Simplest way is to take a second battery and charge it through a diode
from the main bettery. That way if the main battry has a major short
somewhere it will not drag down the second batery with it.
The problem with diodes is they all have a forward volt drop, standard
diodes are about 1 volt drop. So if your system charges at say 14.2
volts, your second battery will only see 13.2V.
I believe the Shotkey (sp?) diode has a much lower drop...Althouigh I
don't know what it is.
My way round this issue on my current plane is to use a smaller battery
for the second ignition that requires a lower charging voltage.
So my first battery is a 18AH and my backup is a 3AH, and is used to run
one EI and a Facet fuel pump, nothing else.
No points of interconnect between the systems except for the diode.
Make sure the diode is sized to flow enough current to run your backup
EI and you can simply run your backup EI from the second battery all the
time, i.e no chageover contactors or other components that could fail.
If you do it this way there is really no need to montior the second
battery as you will be changing it every year or so anyway...I use a
simple digital voltmeter and check it before each flight.
All the best
Frank
Zenair zodiac 400 hours
RV7a...ALMOST finished..Smile
BigD(at)DaveMorris.com
PostPosted: Fri Feb 24, 2006 8:46 am    Post subject: Baclup Battery monitor Reply with quote
Facet pumps draw about 1.5A, don't they? And your EI draws how much? 3AH
seems awfully small to me. I'm guessing the Duration vs Current curve for
that battery gives you 3A for 30 minutes. Is that enough?
Dave Morris
www.N75UP.com
nuckollsr(at)cox.net
PostPosted: Fri Feb 24, 2006 9:02 am    Post subject: Baclup Battery monitor Reply with quote
At 08:22 AM 2/24/2006 -0800, you wrote:
<frank.hinde(at)hp.com>
Which is a major issue for recharging the standby battery
to 100% of capacity.
Battery size does not drive ideal charging voltage. We use the
same Battery Tender products to maintain 1.5 a.h. batteries as
for 50 a.h. batteries. Ideal voltage for charging is driven by
chemistry first and temperature second.
There's been some discussion about optimizing charging protocols
based on flooded vs. gel vs. RG which have proven to be a third
order concern. IF you use a battery as motive/standby power
and IF it's regularly discharged to a fraction of capacity and
immediately recharged then you MIGHT see some increase in service
life with a pampering suggested by folks who program smart chargers.
For all others where you crank first, stabilize alternators second
and supply standby power perhaps once in a lifetime of the battery,
the magic charging protocols yield no measurable return on investment.
As described in other posts, an open circuit voltage check
of a battery is a very gross examination of battery condition
(at least it's not discharged) and yields no accurate data
as to capacity. The yearly change-out is the practical hedge
against the unknown.
A series of articles have been crafted dealing with second battery
management techniques:
http://aeroelectric.com/articles/lvwarn/LVWarn-ABMM.html
http://aeroelectric.com/articles/lvwarn/9021-620.pdf
http://aeroelectric.com/Catalog/AEC/9005/9005.html
http://aeroelectric.com/Catalog/AEC/9005/9005-701B.pdf
These are illustrated in appendix Z, most notably
Figure Z-30 of:
where the aux battery switching device can be any
size of switch or contactor suited to the task and the
battery can also be selected for capacity suited to
the task.
Key considerations are: (1) connect the standby battery
to the main system via lowest practical resistance i.e.
toggle switch or relay. (2) Have active notification of
low voltage that prompts you to open the switch or automatically
opens a relay or contactor . . . it doesn't matter.
You have PLENTY of time to react and there's little
advantage in making this function automatic. The hard
connection through a switch or relay insures that your
standby battery gets the same benefits of recharge as
your main battery.
PostPosted: Fri Feb 24, 2006 9:03 am    Post subject: Baclup Battery monitor Reply with quote
I measured the Facet and it was less than an amp...Can't remember what
the EI draws but I did measure it at the time.
The Zodiac is strictly a VFR airplane and most failure modes would leave
some juice left in the main battery.
So I think I assumed about 20 minutes of flight on Batt #2.
If I were re-doing it today I think the more modern diode (with lower
volt drop) would mean I could use a bigger battery.
Frank
rv8ch
PostPosted: Fri Feb 24, 2006 9:04 am    Post subject: Baclup Battery monitor Reply with quote
Use one of Eric's Power Schotty diodes - they don't have much
voltage drop at all.
http://www.periheliondesign.com/powerschottkydiodes.htm
Mickey Coggins
http://www.rv8.ch/
#82007 finishing
Mickey Coggins
http://www.rv8.ch/
PostPosted: Fri Feb 24, 2006 9:27 am    Post subject: Baclup Battery monitor Reply with quote
Interesting,
The battery manufacturer actually dictated the charging voltage as being
lower for the smaller battery. Both are SLA's.
The other piece I missed about my battery maintenance is that they are
connected to a smart charger when left in the hangar, so at least I have
a good charge when I start out.
Based on the above would you recommend raising the charging voltage by
using a lower loss diode?...I could change for a switch but that gives
me something else I have to remember.
Cheers
Frank
mprather(at)spro.net
PostPosted: Fri Feb 24, 2006 1:03 pm    Post subject: Baclup Battery monitor Reply with quote
Is the Facet pump used continuously? Or only for takeoff, landing, or in
the event of a main (engine driven) pump failure? If only intermittent
duty, leave it out of the backup battery power budget. The chances of an
alternator failure, and an engine driven pump failure on the same flight
are exceedingly low...
Matt-
(Corvallis)" <frank.hinde(at)hp.com>
Frank
PostPosted: Fri Feb 24, 2006 2:00 pm    Post subject: Baclup Battery monitor Reply with quote
I have two electric pumps One in each wing root. No mechanical fuel
pump.
The FI RV is being set up the same way.
To switch tanks I simply switch pumps.
PostPosted: Sat Feb 25, 2006 4:15 pm    Post subject: Baclup Battery monitor Reply with quote
Oh right.. I think I forgot that from the initial discussion. Thanks..
Matt-
pump.
