Rectifier-Regulator
jackandval
PostPosted: Sat Nov 17, 2007 6:03 pm    Post subject: Rectifier-Regulator Reply with quote
I have a Rotax 912 and it is overcharging. I can't find anything in the manuals of how to check if it is a bad regulator. If it is charging does that mean it is a bad regulator?
Jack
Gilles.Thesee(at)ac-greno
PostPosted: Sat Nov 17, 2007 6:21 pm    Post subject: Rectifier-Regulator Reply with quote
Jack,
We'll need some additional info.
What voltage do you read, where and when ?
What is the corresponding engine RPM ?
How does the number of devices connected to the ship's circuit affect
the readings ?
What is the state of your battery ?
How does actual charge influence the voltage readings ?
Do you have the requested capacitor installed ?
Have you checked every connection and wire, especially regulator ground ?
Etc.
Also, a schematic of your wiring will help interpreting the symptoms. It
often boils down to bad wiring.
Best regards,
Gilles
http://contrails.free.fr
jackandval
PostPosted: Sun Nov 18, 2007 5:25 am    Post subject: Re: Rectifier-Regulator Reply with quote
In cruise (at)5200 RPM the voltmeter indicates about 13.5 to 14.0.
If I load the system down, lights, radio,and strobes the amp meter will go from 20 amps to about 10 amps.
Yes the capacitor is correct. No loose connections and good ground.
Battery after flight was checked a few hours later and reads 11.8 or 9
which sort of makes the battery suspect?
But my question was how do you test the regulator??????
Jack
pwmac(at)sisna.com
PostPosted: Sun Nov 18, 2007 6:33 am    Post subject: Rectifier-Regulator Reply with quote
You do NOT have a regulator issue. You do might have a bad battery
since the voltage is so low.
IMO, cover up the amp meter and pay attention to the voltmeter. If
the voltage stays as you indicated all is well with the alternator
and regulator.
After flight a good battery should read above ~12.7+ and as high as
13.5+ Of course if you are exceeding the alternator capability then
the battery would not be fully charged. and could account for low
batt voltage. Do the following on your next flight: Operate with the
lowest electrical load you can and then check the batt volts an hour
after flight then again in 24 hours. If the batt stays above ~12.7,
then the batt is ok and you are just overloading he wimpy Rotax
alternator. You could also verify the batt is good with an overnight
charge at the 2 amp rate then wait 24 hours for it to loose its
surface charge then see what the voltage is.
Paul
Jack
http://forums.matronics.com/viewtopic.php?p=146838#146838
Float Flyr
PostPosted: Sun Nov 18, 2007 8:53 am    Post subject: Rectifier-Regulator Reply with quote
The test for the regulator is to use a voltmeter... You're past that stage.
The generator has to put out a voltage above that of the battery,
theoretically 12 V. to allow the battery enough EMF to charge. Most
regulators are set to 13.8V., rounded off that's 14V which is what the
certified planes rate their busses.
Sounds to me like your regulator/rectifier is doing just fine.
Noel
[quote] --
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
jackandval
PostPosted: Sun Nov 18, 2007 2:54 pm    Post subject: Re: Rectifier-Regulator Reply with quote
Thanks Guys! I think your right that it is the battery. I am charging the battery and will see what it reads tomorrow.
Jack
