Splicing strobe wires
Jekyll
PostPosted: Wed Feb 22, 2006 1:57 pm    Post subject: Splicing strobe wires Reply with quote
When building my wings, I installed the strobe wires in a conduit and cut them off, leaving only a 2 foot length on the root end. That was before I started learning about wiring. Now I have to learn how to connect my installation. I'm using the Whelen system 6 in an RV-7A (3-wire shielded cable, single power supply.)
a. Can I splice the cables to extend them to the power supply? If I do, do I treat the shields as fourth wires and splice those also? If I do this, how do I splice the shield (solder or crimp)?
b. Do I install a molex with 4 pins, 1 for the shield, at the root bulkhead? (I guess this was my original concept when I cut the wires)
c. Should I replace the wires so I have an unbroken run to the power supply? I can probably pull a replacement through if need be.
I'm concerned about RMI from the cable. Whelen says to ground the shield only at the power supply.
Jekyll
nuckollsr(at)cox.net
PostPosted: Wed Feb 22, 2006 6:20 pm    Post subject: Splicing strobe wires Reply with quote
Yes
Yes
Your choice.
yes
no problem if you have no heartburn over the connector/
no
Not necessary
That's correct. Shielding breaks ELECTROSTATIC coupling of noise
and the few inches of exposed wiring at the connector location is
a microscopic risk. Open shields are not "leaks in the dam where
torrents of noise pour out."
< with experiment. >
< --Lawrence M. Krauss >
Joemotis(at)aol.com
PostPosted: Wed Feb 22, 2006 6:53 pm    Post subject: Splicing strobe wires Reply with quote
Thank you Bob, I have always wondered how significant the unsheilded molex
was in noise.
And as I guessed and you pointed out, it's nada.
Joe
