Sea Doo Rotax
river1
PostPosted: Wed Oct 10, 2007 5:37 pm    Post subject: Sea Doo Rotax Reply with quote
Are the 2stroke sea doo engines same as ski doo and the aircraft version ? .
Malcolmbru(at)aol.com
PostPosted: Wed Oct 10, 2007 5:43 pm    Post subject: Sea Doo Rotax Reply with quote
yes just like a goat and a horse are alike they both have the same number of legs a head and a tail.
Float Flyr
PostPosted: Thu Oct 11, 2007 5:22 am    Post subject: Sea Doo Rotax Reply with quote
The ones I've seen certainly don't look the same.
Noel
[quote] --
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
inquire(at)CHESTERMAN.CA
PostPosted: Thu Oct 11, 2007 5:55 am    Post subject: Sea Doo Rotax Reply with quote
They are different engines but some of the parts are the same. If you find
the right model the gaskets interchange as do most of the rotary valve
parts. from there things differ.
dave chesterman.
back on the list after a long break. 701-582
ProWash
PostPosted: Thu Oct 11, 2007 7:47 pm    Post subject: Re: Sea Doo Rotax Reply with quote
I think the important difference is that the Sea Doo Rotax doesn't have a integral water pump.
R Craig
North Central Arkansas
N701LR CH701 SP ELB
30 HRS into Phase One testing
river1
PostPosted: Fri Oct 12, 2007 5:12 am    Post subject: Re: Sea Doo Rotax Reply with quote
Thanks for helping ; the reason I ask is that they are plentyfull around here . You guys think , provided the right model , that a conversion could be made ? .
PostPosted: Fri Oct 12, 2007 7:17 am    Post subject: Sea Doo Rotax Reply with quote
also sea doo crankshafts have threaded ends unlike the sleds and aviation
motors. so first thing you would have to do is change the crankshaft.
dave c
river1
PostPosted: Fri Oct 12, 2007 11:05 am    Post subject: Re: Sea Doo Rotax Reply with quote
Dave ; you seem to know , so do you think is worth the effort in terms of money savings ? . The other option that I cosider is buying a runout and rebuild it .
PostPosted: Fri Oct 12, 2007 11:45 am    Post subject: Sea Doo Rotax Reply with quote
I have been trying to use the lowest cost method for awhile.
The sled motors are the closest but you get single ignition. Some areas just
put a gearbox on a sled engine and when they run out they go to the skidoo
dealer and buy a new long block.
I prefer to keep the dual ignition and have stuck with the aviation motors
but use rebuilt cranks from a good engine builder. gaskets i get from
aftermarket which are the same as some sleds. I use water pump rv shaft
stuff from the 580 seadoos from about 1990.
If you have nothing now I would buy the cheapest complete aviation 582 i
could find( holes in the case, broken crank and everything) to get the
carbs, igintion ,gearbox, exhaust, etc and then buy a new long block blue
head 582. and make one engine. That is the least expensive way to go if you
find a low cost doner engine.
If you find a good runout 582 you can get them rebuilt by one of the
national engine rebuilders using aftermarket sled stuff for about 1500 but
don't tell them its form a plane or the work stops there.
using rotax aviation parts to completely rebuild a runout engine will cost
about the same as a new short block
dave c
From: "river1" <pedro(at)mycingular.blackberry.net>
To: <rotaxengines-list(at)matronics.com>
Sent: Friday, October 12, 2007 3:05 PM
Subject: Re: Sea Doo Rotax
rebuild it .
http://forums.matronics.com/viewtopic.php?p=139624#139624
river1
PostPosted: Fri Oct 12, 2007 12:47 pm    Post subject: Re: Sea Doo Rotax Reply with quote
Very good Dave ; Do you mind pointing to the rebuilders , source for short blocks etc. . If you want do it off line , I didn't mention , but the project in question is a 701 . Thx
Float Flyr
PostPosted: Sat Oct 13, 2007 3:58 pm    Post subject: Sea Doo Rotax Reply with quote
As soon as your local SkiDoo shop sees the dual ignition they will start to
ask questions and as you say the work stops there.
Noel
[quote] --
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
river1
PostPosted: Sat Oct 13, 2007 4:37 pm    Post subject: Re: Sea Doo Rotax Reply with quote
Noel ; There are no local ski- doo shops here only sea-doo , and I think most local techs don't care as long as you pay . Thx .
