jorgen.nielsen(at)mweb.co Guest
Posted: Tue Oct 09, 2007 11:45 pm Post subject: Wheel balance |
How do you guys balance the wheels on your L29s? I had mine done but with those sticky weights that I then pulled off as I was concerned it would come off and go through engine.
I thought to do it again, but mark the position, remove, and re-attach using epoxy.
Jorgen
| - The Matronics L29-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?L29-List |
colyergreg(at)aol.com Guest
Posted: Wed Oct 10, 2007 5:20 am Post subject: Wheel balance |
We don't
Sent from my iPhone. Have a great day!
Greg
On Oct 10, 2007, at 12:44 AM, "Jorgen Nielsen" <jorgen.nielsen(at)mweb.co.za (jorgen.nielsen(at)mweb.co.za)> wrote:
Jorgen
delfin(at)mail.pf Guest
Posted: Wed Oct 10, 2007 10:14 am Post subject: Wheel balance |
I thing it is a good idea. In fact, only the nose wheel needs sometimes a balance. By chance, mine is perfectly balanced without anything.Jorgen, have-you any news for the cartridges ?
Le 10 oct. 07 à 03:18, Colyergreg a écrit :
[quote]We don't
Greg
Jorgen
href="http://www.matronics.com/Navigator?L29-List">http://www.matronics.com/Navigator?L29-List
| [b]
Posted: Wed Oct 10, 2007 11:08 am Post subject: Wheel balance |
My front wheel has a terrible vibration – tyre is out of balance and I must do something.
From: owner-l29-list-server(at)matronics.com [mailto:owner-l29-list-server(at)matronics.com] On Behalf Of Colyergreg
Sent: 10 October 2007 03:19 PM
To: l29-list(at)matronics.com
Subject: Re: Wheel balance
We don't
Have a great day!
Greg
Jorgen
| 0123456
Posted: Wed Oct 10, 2007 11:10 am Post subject: Wheel balance |
Yes also my front tyre. Will let you know re cartridges via email.
From: owner-l29-list-server(at)matronics.com [mailto:owner-l29-list-server(at)matronics.com] On Behalf Of delfin(at)mail.pf
Sent: 10 October 2007 08:13 PM
We don't
Have a great day!
Greg
Jorgen
href="http://www.matronics.com/Navigator?L29-List">http://www.matronics.com/Navigator?L29-Listhref="http://forums.matronics.com">http://forums.matronics.com |
0123456789
delfin_driver(at)yahoo.co Guest
Posted: Wed Oct 10, 2007 1:43 pm Post subject: Wheel balance |
have to balance tires and use internal stick on weights that go between wheel and intertube. only safe way to get ride of vibration. with the jets ouside weights are dangerous, can come off and be sucked in., I got rid of all vibration using this method also works for the YAK
bob schwartz
Posted: Wed Oct 10, 2007 1:55 pm Post subject: Wheel balance |
Are these special type weights or the normal ones? I.e, are they rounded to prevent puncturing the tube?
From: owner-l29-list-server(at)matronics.com [mailto:owner-l29-list-server(at)matronics.com] On Behalf Of Robert Schwartz
Sent: 10 October 2007 11:43 PM
bob schwartz
----- Original Message ----
From: Jorgen Nielsen <jorgen.nielsen(at)mweb.co.za>
Sent: Wednesday, October 10, 2007 2:09:33 PM
Subject: RE: Wheel balance
We don't
Have a great day!
Greg
Jorgen
Quote: | http://forums.matronic=============== |
Check out the hottest 2008 models today at Yahoo! Autos. [quote][b]
http://www.matronics.com/Navigator?L29-List the Web href="http://forums.matronics.com">http://forums.matronics.com ===========
czech6(at)kellin.net Guest
Posted: Wed Oct 10, 2007 2:22 pm Post subject: Wheel balance |
First make sure you pre-load the bearings a little. (tighten the nut another turn.) If you jack it up and spin it hard with your hand, you don't want it to keep spinning. Maybe 1 to 1 1/2 times around then it stops. I take mine to the auto tire shop . They can "Turn" the brake drums, and spin balance your front wheel. Glue the weights in, or remove the tire and use truck tire weights that are made to go inside the tire exactly where you need them. The tube as well as the sticky glue on them hold the weights in place.
Bill
Posted: Wed Oct 10, 2007 2:25 pm Post subject: Wheel balance |
They are rubber.
Posted: Wed Oct 10, 2007 2:39 pm Post subject: Wheel balance |
Aha! Thanks Bill.
That sounds like a properly engineered solution.
I wonder if one could balance car tyres the same way – no ugly weights on the rims. Of course there is no tube to hold it tho, would have to attach it really well.
From: owner-l29-list-server(at)matronics.com [mailto:owner-l29-list-server(at)matronics.com] On Behalf Of Bill
Sent: 11 October 2007 12:22 AM
Bill
Quote: |
----- Original Message -----
From: Jorgen Nielsen (jorgen.nielsen(at)mweb.co.za)
To: l29-list(at)matronics.com (l29-list(at)matronics.com)
Sent: Wednesday, October 10, 2007 1:44 AM
Subject: Wheel balance
Jorgen
Quote: | href="http://www.matronics.com/Navigator?L29-List">http://www.matronics.com/Navigator?L29-Listhref="http://forums.matronics.com">http://forums.matronics.com | | 0123456789
Posted: Wed Oct 10, 2007 7:35 pm Post subject: Wheel balance |
That is how I did my long haul trucks when I was in the business. They sell the weights over here. They actually have a stickey surface. We use extra glue to be sure they stick. No tubes either.
Posted: Fri Oct 12, 2007 8:42 am Post subject: Wheel balance |
Had mine done today. Will fit and test tomorrow.
Thanks to all – this is definitely the right way to do it!
Sent: 11 October 2007 12:25 AM
They are rubber.
