stater plate 582
Malcolmbru(at)aol.com
PostPosted: Sat Oct 06, 2007 6:14 pm    Post subject: stater plate 582 Reply with quote
today I burned out my charging coil , 76 hrs ago I lost the tack coil so I ran a tiny tack the first thing I noticed was a drop in my charging volts just a little low then it dropped way off after about 3 hrs flying time when I used my strobe and lights after inspecting the charging wires i found a burnt wire and only 9 oms on my charging circuit.  $600 and 4 hrs labor and i will be back in the air. malcolm kit fox michigan
See wha [quote][b]
