Wire label printers
Terry Watson
PostPosted: Fri Feb 17, 2006 6:09 pm    Post subject: Wire label printers Reply with quote
I don't think this has been noted on this list before. Dymo has some
hand-held printers that work with wiring labels for under $100 now. Here is
a link to the pdf file on one of the printers:
http://dymo.com/img/compel/JaMWjqkn1vU_tszsSsYIER1uURG4VVCg.pdf
This is a link to their website for the $50 printer that will do wiring
labels:
http://dymo.com/enUS/Products/RhinoPRO_1000.html
Terry
RV-8A finishing?
Seattle
Joemotis(at)aol.com
PostPosted: Fri Feb 17, 2006 8:18 pm    Post subject: Wire label printers Reply with quote
In a message dated 2/17/2006 6:11:25 PM Pacific Standard Time,
terry(at)tcwatson.com writes:
I use the earlier by one version of this machine at work and my comment is
"It rocks".
Great tool, ergonomically and functionally.
Joe
rondefly(at)rtriano.com
PostPosted: Mon Feb 20, 2006 11:35 am    Post subject: Wire Label Printers Reply with quote
I found on ebay the Dymo Pro 5000 brand new for 80.00. Here are the specs.
These things will even do shrink tube labeling.
. Meets ANSI/TIA/EIA-606-A labeling standards.
. "Hot keys" provide automatic label formatting for wires and cables,
terminal blocks, patch panels, vertical and fixed length labeling.
. Advanced wire gauge function. Just select the wire gauge or cable size and
RhinoPRO sets up the label precisely.
. Features common datacom and electrical symbols: ohm, ground, phone, data
and fax
. Prints up to 12 characters for vertical wraps.
. Automatically underlines 6's and 9's for wire and cable marking.
. Smear-proof thermal printing resists solvents, heat and moisture.
. Ten-label memory for fast results.
. Prints Code 39 and Code 128 bar codes
. Prints five text sizes.
. Includes impact-resistant rubber bumper.
. Automatic shut-off saves battery life.
. Bright yellow color means this tool won't get lost.
. Fits in the palm of your hand.
. Uses 6 AA batteries (not included).
. Weighs just over 1 lb.
. Package includes one RhinoPRO 5000 with impact-resistant bumper, one
RhinoPRO 3/4" (19 mm) flexible nylon label cassette, User Manual.
Ron Triano
http://bld01.ipowerweb.com/contentmanagement/websites/rtrianoc/page10.html
