running vacuum pump without load, bad idea?
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Engines-List
CardinalNSB(at)aol.com
PostPosted: Mon Sep 17, 2007 6:09 am    Post subject: running vacuum pump without load, bad idea? Reply with quote
Is it harmful t run the engine with the vacuum pump attached to the engine but the suction end free to pull in air, what is the best way to ground run engine with no load on vacuum pump? thanks skip
Make AOL Your Homepage.
- The Matronics Engines-List Email Forum -
http://www.matronics.com/Navigator?Engines-List
Float Flyr
PostPosted: Mon Sep 17, 2007 10:12 am    Post subject: running vacuum pump without load, bad idea? Reply with quote
Vacuum pumps are generally vane pumps designed for large volume that the instruments they power require. Lab vacuum pumps are designed to evacuate air from small volumes.
Running shouldn't hurt but I'd put a filter on the intake end to keep grit out.
Noel
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Engines-List All times are GMT - 8 Hours
