Radio Static
john(at)totten.com
PostPosted: Sun Feb 19, 2006 5:58 pm    Post subject: Radio Static Reply with quote
What are the sources and cures for radio static?
I spent $10,000 on a Garmin 430 and have big time squelch
problems which sometimes make the radios unusable.
JohnT
skywagon
PostPosted: Sun Feb 19, 2006 6:25 pm    Post subject: Radio Static Reply with quote
John,
If the squelch "breaks" always occur on specific 430 set frequencies, then,
it is a problem in the 430. I had to send my 430 back to Garmin and they
fixed it. My 430 had a problem with 132.200.
If the squelch break is random then, who ever installed the 430 should go
through the software squelch adjustment procedures. If that does not fix
things then, you have an RF noise problem. It is know that some earlier
models of KX-155's comms. radiate quite a bit stray RF and that will set off
the more sensitive Garmin 430 receiver. Other comm's may do the same.
D..
john(at)totten.com
PostPosted: Sun Feb 19, 2006 7:11 pm    Post subject: Radio Static Reply with quote
Does anyone know how to adjust the auto-squelch on the
Garmin 430? I imagine this needs a Service Login and
password?
JohnT
skywagon
PostPosted: Sun Feb 19, 2006 8:48 pm    Post subject: Radio Static Reply with quote
John,
The adjustment of the 3 bands of 430 squelch is fairly complicated.
It takes the proper service manual and a very accurate signal generator with
very good low level attenuation capability.
D
Gilles.Thesee(at)ac-greno
PostPosted: Mon Feb 20, 2006 2:40 am    Post subject: Radio Static Reply with quote
John Totten a crit :
password?
JohnT
John,
If you don't have it the 430 manual, you can see
http://contrails.free.fr/gps_manuels.php
FWIW,
Gilles Thesee
Grenoble, France
