No Title
pm(at)tecnam.co.uk
PostPosted: Fri Sep 14, 2007 6:52 am    Post subject: No Title Reply with quote
Paul,
I have a Tecnam Sierra with a Dynon D10 engine monitor with the Flowscan 201 sensor which is mounted in the fuel line AFTER the "return to tank bleed" and before the lines split to each carburettor so it only reads fuel actually being used by both . Works fine and I believe very accurate.The Dynon counts the pulses put out by the flowmeter.I do not know if it compatible to other flow sensing devices. You will have to ask Dynon
Paul Mitchell
