SV: Rocker arm & Valve clearance
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> M14PEngines-List
haavard-iversen(at)c2i.ne
PostPosted: Wed Sep 12, 2007 1:39 pm    Post subject: SV: Rocker arm & Valve clearance Reply with quote
It is 0.3 med mer that is correct for both!
www.yaknorway.com
-----Opprinnelig melding-----
Fra: owner-m14pengines-list-server(at)matronics.com
[mailto:owner-m14pengines-list-server(at)matronics.com] På vegne av John
Nafziger
Sendt: 10. september 2007 22:54
Til: m14pengines-list matronics.com
Emne: Rocker arm & Valve clearance
I went over the rocker arm & valve clearance per the maintance manual
(task card 247). It states a clearance of 0.3 mm for both valves,
cold.
The clearances on mine (romanian m14p) were mostly 0.3 mm for the
intake valves, but 0.45 mm for the exhaust valves. I set them all at
0.3 mm per the manual, but due to the consistancy of the exhaust
settings, I thought I'd ask if anyone has found a similar thing?
The placard on the nose case states 0.010", but I thought 0.012"
(0.3mm) close enough.
http://smallbusiness.yahoo.com/webhosting
- The Matronics M14PEngines-List Email Forum -
http://www.matronics.com/Navigator?M14PEngines-List
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> M14PEngines-List All times are GMT - 8 Hours
