Special switch
trigo(at)mail.telepac.pt
PostPosted: Sat Feb 18, 2006 9:57 am    Post subject: Special switch Reply with quote
I am looking for a DPDT On-On-On switch, like the 2-10 from B&C but in
miniature or sub-miniature version.
Does anybody know a source for it ?
Carlos
nuckollsr(at)cox.net
PostPosted: Sat Feb 18, 2006 12:02 pm    Post subject: Special switch Reply with quote
At 05:52 PM 2/18/2006 +0000, you wrote:
<trigo(at)mail.telepac.pt>
Sure. This would be a C&K 7211SYZQE available from Digikey.
The descriptors on page
http://dkc3.digikey.com/PDF/T061/1385.pdf
are correct. Descriptors in the order building page
at
http://www.digikey.com/scripts/DkSearch/dksus.dll?Criteria?Ref=15385&Site=US&Cat=34407579
are hosed up. It doesn't have and LED, is not DP4T,
doesn't mount in a 15 x 5.5 mm hole, not rated for 582 Amps
and is not an On-Off-On switch . . . other than all
that confusion, the part number is correct for a DP3T,
On-On-On progressive transfer switch. You can confirm this
from the C&K catalog second illustration from the top on
page 2 of:
http://rocky.digikey.com/WebLib/C%26K%20Components/Web%20Data/7000%20Series.pdf
< with experiment. >
< --Lawrence M. Krauss >
PostPosted: Sat Feb 18, 2006 3:48 pm    Post subject: Special switch Reply with quote
Thanks Bob
Already ordered it
Carlos
JTORTHO(at)aol.com
PostPosted: Sun Feb 19, 2006 4:48 am    Post subject: Special switch Reply with quote
Carlos
Try this link for ebay. I bought five, but have not yet tried these
switches. They came in a day or two ago. They are sub miniature. I don't need more
then two, I could drop one in the mail if you like.
What is the best way to make a secure connection to these small contacts?
http://cgi.ebay.com/PCK-12-MINI-DPDT-Toggle-Switches-ON-ON-ON-UL-SWITCH_W0QQit
emZ7390380626QQcategoryZ47076QQcmdZViewItem
Jim
Searey
multitasking
too cold in the garage
PostPosted: Sun Feb 19, 2006 5:59 am    Post subject: Special switch Reply with quote
Jim
By the picture, they look SPDT (only 3 connectors) and I need DPDT (6
connectors).
I already ordered from DigiKey, thanks anyway.
For the best connection, I prefer to use spade terminals, if you find the
appropriate size. Otherwise you'll have to solder it.
Carlos
s_s_and(at)hotmail.com
PostPosted: Sun Feb 19, 2006 9:21 am    Post subject: Special switch Reply with quote
You can order one from Mouser at mouser.com. I have gotten switches from
them, the problem is wading through all the products. They have a catalog
online or will send you one.
Steve Anderson
Final wiring
RV 7a
Reply-To: aeroelectric-list(at)matronics.com
To: <aeroelectric-list(at)matronics.com>
Subject: Special switch
Date: Sat, 18 Feb 2006 17:52:11 -0000
Carlos
