Molex Tool
Jerry Cochran
PostPosted: Thu Feb 16, 2006 9:59 am    Post subject: Molex Tool Reply with quote
Any Avionics shop, or might be easy to make. Mine is SS, measures
.022x.053x.400" on business end.
Jerry
Speaking of Molex connector pins, the A200 installation manual refers to a
Molex connector pin removal tool.
Where can it be obtained?
Carlos
bnoon12(at)comcast.net
PostPosted: Thu Feb 16, 2006 12:22 pm    Post subject: Molex Tool Reply with quote
Carlos,
After reading your post, I found this web page that seems to answer your question and supports Jerry's answer as well.
bruce
(520) 760-5925
Tucson,AZ 85750
Jerry
Carlos
Carlos,
bruce
(520) 760-5925
Tucson,AZ 85750
-- AeroElectric-List message posted by: Jerry2DT(at)aol.com
Jerry
Carlos
t, FAQ,
http://www.berkut13.com/extractor.htm
Carlos,
bruce
(520) 760-5925
Tucson,AZ 85750
Jerry
Carlos
Carlos,
bruce
(520) 760-5925
Tucson,AZ 85750
Jerry
Carlos
t, FAQ,
stein(at)steinair.com
PostPosted: Thu Feb 16, 2006 4:42 pm    Post subject: Molex Tool Reply with quote
There are a few "double secret" ways to make your own tool and save the $40
for the Mil Spec one which you'll break just as quickly.
1) Take a hacksaw blade, cut it to about 4 inches long, then take it over to
the belt sander and make a nice pointy end on it that is about .030" wide.
Works perfectly and when you break it (not if, but when), you just go make
it new again!
2) unfold a paper clip, then smash one end of it flat for about 3/8" inch
with a hammer. Works well in a pinch.
3) do the same as step 2 with one your wifes Bobby Pins
4) Same as above with .030 or .040 safety wire.
All of the above work great, but the most robust is to use an old hacksaw
blade and your sander to create a $40 tool for about $.50.
Just my 2 cents an usual!
Stein.
P.S., remember that if you're a bit "over agressive" on pushing up the tang
when you remove those pins that they won't stay inserted the next time you
put them into the right slot unless you reshape it slightly.
[quote]--
sportav8r(at)aol.com
PostPosted: Thu Feb 16, 2006 5:02 pm    Post subject: Molex Tool Reply with quote
How does one go about using this tool to remove pins? The professional tools I've (tried to) use are cylindrical. Does one take the flat blade you describe and pry inward on each ear of the pin, one at a time? How to keep the other side from springing back?
-Bill B
nuckollsr(at)cox.net
PostPosted: Thu Feb 16, 2006 5:35 pm    Post subject: Molex Tool Reply with quote
-Bill B
The typical terminal has a barb on the side away
from the spring loaded electrical contact. See:
http://www.aeroelectric.com/Mfgr_Data/Connectors/Molex_2478_Pins.pdf
When inserted into the housing, the barb engages
a notch on the housing's inside surface as shown in
cross section Z-Z of:
http://www.aeroelectric.com/Mfgr_Data/Connectors/Molex_6422.pdf
To extract the pin, a thin rectangular probe of appropriate
dimensions is pushed along side the terminal from the
board-side face such that it depresses the barb and releases
the pin.
Before re-inserting a pin, it's a good idea to spring the barb
outward a tad . . . extracting them often causes the barb to
lay flatter against the terminal and compromises retention.
riggs_la(at)yahoo.com
PostPosted: Thu Feb 16, 2006 6:36 pm    Post subject: Molex Tool Reply with quote
One end should be cylindrical but the other end should have a side open so you can slip it over the pin.
-Bill B
PostPosted: Thu Feb 16, 2006 7:30 pm    Post subject: Molex Tool Reply with quote
Oh. Never mind Smile I was thinking of the round pins, as in Mate-N -Loc, and Radio Shack variety Molex connectors. I've never encountered the type you're depicting here.
If I do, I'll keep that in mind. Meanwhile, I find the commercial extractor tools for the round-barrel pins are really hard to use and cause profanity Wink
-BB
