Piper Style Ground Power
nuckollsr(at)cox.net
PostPosted: Wed Feb 15, 2006 6:31 pm    Post subject: Piper Style Ground Power Reply with quote
>Reviewing the diagram of the "piper" style ground power plug in Z-31B it
>appears that once external power is applied, the contactor would stay
>energized forever (at least until the battery was killed) since the
>engergizing current would flow backward through the contactor and through
>the solenoid coil. Is there a key point I'm missing or is an interrupt
>switch of some kind called for?
Yup, it's called the ground power control switch illustrated
in this case as a switch-breaker in the lower left quadrant
of the drawing. If you want to use a miniature push-pull breaker,
then an additional switch is called for . . . or you could use
the breaker itself as the controlling device. It's a VERY low
usage item and I'd have no heartburn about using the breaker
as a switch in this case.
< with experiment. >
< --Lawrence M. Krauss >
