Don G
Joined: 10 Jan 2006 Posts: 156 Location: Central Illinois
Posted: Wed Jul 18, 2007 7:31 am Post subject: tiny Tach for a 912? |
Some time back, I remember Fred asking about the model of a tiny tach for a 912. Never did find a response. Anbody know which model tiny tach to use for a 912 UL?
Just how does this ignition fire anyway?
1 spark per rev?....2 sparks per rev? 1 every 4?...hmmm
_________________ Don G.
Central Illinois
Kitfox IV Speedster
Luscombe 8A
RV9A |
kitfoxmike
Posted: Wed Jul 18, 2007 8:13 am Post subject: Re: tiny Tach for a 912? |
they are a piece of junk, I got one and could never get it to work right, I gave up and threw it in the corner of the hangar.
Don G
Posted: Wed Jul 18, 2007 8:23 am Post subject: Re: tiny Tach for a 912? |
Mike, They cant be to good, they are so cheap...but then this Rotax tach I have is at least 200 rpms off and it costs like he!!
I have a Sendec on my boat and I think I might try to put it on the 912.
still trying to figure out its programming!
Hey, did you see my post on the strut covers you have?
Tell me more about the "self Adjusting" feature...et...not fastening them down tite.
Do they vibrate of rattle in flight?
any wear noticable?
Do they ever get "out of whack" in flight and stay there?
How about donw at the bottom where the struts come together?..how did you dashion them for clearance?interferance?
This seems to be a great answer to trying to decide what angle of attach to attach them!
Thx!
Central Illinois
Kitfox IV Speedster
Luscombe 8A
RV9A |
Float Flyr
Posted: Wed Jul 18, 2007 11:11 am Post subject: tiny Tach for a 912? |
1 spark every 720 deg. (certified engines) That is why impulse couplers
work. As far as I know all the auto conversions are the same.
Noel
[quote] --
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
kerrjohna(at)comcast.net Guest
Posted: Wed Jul 18, 2007 11:29 am Post subject: tiny Tach for a 912? |
I believe that the 912 is different from auto converstions with a firing every 360 degrees. I have heard the term lost or wasted spark. The plugs fire on both the compression and exhaust stroke as I understand the operation.
I could be wrong though, electricity is a black art. Switching load, switching ground, all sorts of things. Does one ever really knows which way the current is flowing?
And when you figure out that 3-fingered diagram then you can start on the Bing carburetor and their 3 or is 4 different but interrelated circuits.
John Kerr
[quote]-------------- Original message --------------
[quote] --> Kitfox-List message posted by: "Noel Loveys"
Noel
kitfoxmike
Posted: Wed Jul 18, 2007 1:01 pm Post subject: Re: tiny Tach for a 912? |
I made sure I had the right one, the factory for these things sent it to me, I couldn't get a proper rpm reading, they said add more wire and wrap the plug wire some more, I did, didn't work. So I chucked it. There is another one out there that is better, just can't think of the name.
On the strut fairings, I installed them as per instructions, they slip over the struts and snap in the back, they say to glue them in place, I didn't, they work great and center on their own in flight.
torgemor(at)online.no Guest
Posted: Wed Jul 18, 2007 1:47 pm Post subject: tiny Tach for a 912? |
| Quote: | On Wed, 18 Jul 2007 21:26:47 +0200, <kerrjohna(at)comcast.net> wrote:
| Quote: | I believe that the 912 is different from auto converstions with a firing
the operation.
circuits.
John Kerr
Right you are John,
The Rotax use the "wasted" spark ignition system, for both the two strokes
and the four strokes!
As a four stroke need 720 deg between each "full" stroke, the spark will
ignite every 360 deg. The two stroke need 360 for each stroke and will
ignite every 180 deg.
This is a real smart "setup" to obtain redundancy in a ignition system for
our kind of use.
Here is a little link to Wikipedia about such systems:
http://en.wikipedia.org/wiki/Wasted_spark
Cheers
Torgeir
Kitfox Model II, 1993
Engine: Rotax 532 with B gearbox
Propeller: IVO UL 366Q
Tromsoe
NORWAY.
Weather in Tromso right now:
http://met.no/troms/index.html
City map of Tromso:
http://www.avinor.no/English/Airports/Tromso_Airport/?module=Articles;action=ArticleFolder.publicOpenFolder;ID=1453
Using Opera's revolutionary e-mail client: http://www.opera.com/mail/
