912uls with vm1000c
flyingmike9
PostPosted: Mon Jun 11, 2007 11:20 am    Post subject: 912uls with vm1000c Reply with quote
hello has anybody fitted a vm1000c /vm1000 to the rotax 912uls 100hp
if so how easy/hard was it and do you use the senders from rotax or vm
cheers
mike in uk
Roger Lee
PostPosted: Mon Jun 11, 2007 3:09 pm    Post subject: Re: 912uls with vm1000c Reply with quote
Hi Mike,
Looks like Vision Microsystems supports the Rotax 912uls with its vm1000. Usually the company that makes the instrument makes the senders and probes. I see it is a little cheaper than Dynon.
I think your question would be better directed at the Vision Microsystems factory. I have not seen or heard of one of those units on a Rotax, but that's probably not saying much.
I read a little about the units online and don't see a reason why it should be a problem.
As for installation you should have to just mount it in the panel and run all the wires to the appropriate location. I other words "Some Assembly Required".
Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056
flyingmike9
PostPosted: Tue Jun 12, 2007 11:13 am    Post subject: Re: 912uls with vm1000c Reply with quote
thanks for the info
have emailed the company several times but no reply
they have moved head quaters so mabye lost in email abbiss
cheers
mike
rampil
PostPosted: Fri Jun 15, 2007 8:28 am    Post subject: Re: 912uls with vm1000c Reply with quote
Just Curious,
Where did you find out that Vision was now supporting Rotax hardware.
That would be a change from my previous discussions with them at
Oshkosh. There does not seem to be anything related to Rotax on their
website.
Ira N224XS
flyingmike9
PostPosted: Sun Jul 01, 2007 11:34 am    Post subject: Re: 912uls with vm1000c Reply with quote
have email back from vms and they say that the VM1000C will work with the rotax engine but i will have to use the supplied sensors
have ordered one from aircraft spruce with current exchange rate makes the EMS cheaper than dynon and mine comes with fuel flow sensor and all the senders and sensors
no extra charge
mike in uk
