Easy - too easy
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Engines-List
Fergus Kyle
PostPosted: Sat Jun 23, 2007 6:30 pm    Post subject: Easy - too easy Reply with quote
My old math teacher said " When it's easy, be wise, do it twice."
Example:
30c x 2 = 60,
minus 10% (60-6=56),
56 + 32 = 86F
Do it in your head easy
Second time, I don't think so.
Cheers, Ferg
- The Matronics Engines-List Email Forum -
http://www.matronics.com/Navigator?Engines-List
lm4(at)juno.com
PostPosted: Sun Jun 24, 2007 6:21 am    Post subject: Easy - too easy Reply with quote
Hi Folks,
Guess I missed most of this thread. Are we trying to mentally
convert Fahrenheit to Centigrade ?
Larry Mac Donald
lm4(at)juno.com
Rochester N.Y.
On Sat, 23 Jun 2007 22:28:28 -0400 "Fergus Kyle" <VE3LVO(at)rac.ca> writes:
Example:
30c x 2 = 60,
56 + 32 = 86F
Cheers, Ferg
Fergus Kyle
PostPosted: Sun Jun 24, 2007 7:18 am    Post subject: Re: Easy - too easy Reply with quote
Right, Larry,
Basically, the topic was an easy way to convert. However you can see the arithmatic fialed and although the answer was correct, the math wasn't. I was just noting that the easier the arithmatic, the greater the need to do it twice.....
Cheers, Ferg
jrccea(at)bellsouth.net
PostPosted: Sun Jun 24, 2007 9:25 am    Post subject: Easy - too easy Reply with quote
I'm afraid I miss the point. This is indeed the easiest way to mentally
convert from C to F, and is so quick that you can do it as fast as you say
it.
JimC
Float Flyr
PostPosted: Sun Jun 24, 2007 10:36 am    Post subject: Easy - too easy Reply with quote
The first time I've seen it expressed that way
Noel
VO1 PL
[quote] --
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
klwerner(at)comcast.net
PostPosted: Sun Jun 24, 2007 12:50 pm    Post subject: Easy - too easy Reply with quote
60 - 6 *IS NOT* 56, but rather equals 54, no???
And 56 + 32 = 88, and not 86.
But it looks like two wrongs can make things right after all.....
[quote]> Example:
[quote] 30c x 2 = 60,
56 + 32 = 86F
Cheers, Ferg[b]
PostPosted: Sun Jun 24, 2007 1:11 pm    Post subject: Easy - too easy Reply with quote
It's the way I've always done it.
JimC
Float Flyr
PostPosted: Sun Jun 24, 2007 2:00 pm    Post subject: Easy - too easy Reply with quote
(9/5C) +32=F
(F-32)(5/9)=C
That's the way I was shown... A bit bulky for doing without paper or a
calculator. Yours is definitely easier. I tried it on -40C =-40F, 0C=32F,
20C=68F, 100C 12F all worked correctly.
Noel
[quote] --
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
s_korney(at)hotmail.com
PostPosted: Sun Jun 24, 2007 4:38 pm    Post subject: Easy - too easy Reply with quote
Now try it backwards... to get back to Cent.
Best... Steve
----Original Message Follows----
Reply-To: engines-list(at)matronics.com
To: <engines-list(at)matronics.com>
Subject: RE: Easy - too easy
Date: Sun, 24 Jun 2007 19:29:33 -0230
(9/5C) +32=F
(F-32)(5/9)=C
Noel
apilot2(at)gmail.com
PostPosted: Sun Jun 24, 2007 5:06 pm    Post subject: Easy - too easy Reply with quote
One example will show it only gets you within 10%.
-40F=-40C
-40-32/2=-36 does not equal -40.
Best... Steve
(9/5C) +32=F
(F-32)(5/9)=C
Noel
PostPosted: Sun Jun 24, 2007 5:22 pm    Post subject: Easy - too easy Reply with quote
That's because it's exactly the same equation, just configured differently.
9/5X is the same as 2X-2X/10. Both equal 1.8X
JimC
longg(at)pjm.com
PostPosted: Sun Jun 24, 2007 5:39 pm    Post subject: Easy - too easy Reply with quote
Rule of thumb is easiest. Double it and add 30. Normally accurate within
1-2 degrees. Opposite for converting back.
ElleryWeld(at)aol.com
PostPosted: Sun Jun 24, 2007 6:05 pm    Post subject: Easy - too easy Reply with quote
I would think the easiest way to convert in either direction would be to use your flight computer it works for me
Ellery in MAINE
See what's free at http://www.aol.com. [quote][b]
truflite(at)yahoo.com
PostPosted: Sun Jun 24, 2007 6:31 pm    Post subject: Easy - too easy Reply with quote
Should read 2X-(2X/10)+ 32=F. Math in brackets is
done first. Hey, I do remember something from high
school. Very Happy
Dave
JimC
lm4(at)juno.com
PostPosted: Mon Jun 25, 2007 4:41 am    Post subject: Easy - too easy Reply with quote
Thanks Ferg,
That's an annoying little piece of arithmetic. When it's
not critical, and when I can accept an answer within
2 or 3 degrees I use something I learned from a friend
in Toronto. I simply take F. subtract 30 and divide by 2 to get C.
Or take C. double it and add 30. Works a lot of the time for me.
On Sun, 24 Jun 2007 08:18:26 -0700 "Fergus Kyle" <VE3LVO(at)rac.ca> writes:
Right, Larry,
Cheers, Ferg
http://forums.matronics.com/viewtopic.php?p=120344#120344
PostPosted: Mon Jun 25, 2007 8:22 am    Post subject: Easy - too easy Reply with quote
Lets try that, using 100C (the boiling point of water).
2*100+30 30F
The correct answer is 212F
The error is 28F.
Is that close enough? (it's slightly more than 1-2 degrees)
The exact answer requires only one more substraction.
JimC
PostPosted: Mon Jun 25, 2007 8:28 am    Post subject: Easy - too easy Reply with quote
The brackets are optional, not required.
2X-(2X/10) is the same as 2(X-X/10) is the same as 2X-2X/10 is the same as
2X(1-0.1) is the same as 1.8X
Personally, I think its easiest to just do the thing in your head. Smile
JimC
peter(at)us-eurolink.co.u
PostPosted: Mon Jun 25, 2007 9:19 am    Post subject: Easy - too easy Reply with quote
Let's try the UK version:
C to F = double it, less 10%, add 32
Eg 100C x 2 = 200 - 10% = 180 + 32 = 212F
That's pretty close for me!
F to C slightly less accurate
F less 32, add 10%, halve it
Eg 212 - 32 = 180, add 10% = 198, halve it = 99C
Still good enough for me!
Kind regards
Peter Grant - UK Sportcruiser #4 (waiting)
10 The Sidings, Horncastle, Lincs LN9 5UA
England
Tel: +44 1507 523180      Fax: +44 1507 525888  Mob: +7774 923160
This email may contain confidential information; if you have received it in
error please delete it from your system and inform the sender.  Outgoing
messages are scanned by AVG 7 Professional.
rv8vator(at)comcast.net
PostPosted: Tue Jun 26, 2007 7:10 am    Post subject: Easy - too easy Reply with quote
You guys are arguing from the standpoint that the formula is an
approximation. It is an exact conversion, Why?
Because between freezing and boiling there are 100 Centigrade degrees and
180 Fahrenheit degrees. The ratio is 9/5. Centigrade freezing starts at "0"
Fahrenheit starts at 32.
So lets convert 20° C to Fahrenheit .
20 x 9/5 = 36 (The number of Fahrenheit degrees) since Fahrenheit begins at
32° adding 32 to 36 gives us 68°F.
Doubling 20 and subtracting 10 percent is just an easier way than
multiplying by 9 and dividing by 5.
Martin Sobel
PostPosted: Tue Jun 26, 2007 11:40 am    Post subject: Easy - too easy Reply with quote
Ummh, no. I think I specifically said that doubling less 10% was an exact
conversion. Some of the other guys prefer using approximations. I agree
with you.
JimC
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Engines-List All times are GMT - 8 Hours
