Icom A200-Help! (Bobs diagram errata, ICOM corrections)
gmcjetpilot(at)yahoo.com
PostPosted: Sun Feb 12, 2006 9:47 am    Post subject: Icom A200-Help! (Bobs diagram errata, ICOM corrections) Reply with quote
Bob, very nice diagrams, much nicer than mine. Two comments.....
"I'd intended to show how to "dummy load" the speaker
output with an inset on page 2."
Regarding comment about speaker dummy load - I called ICOM and
they told me emphatically that it was not necessary to connect
anything to the speaker load, so your diagram is correct. Other than
that I think we had similar ideas.
The second item is the internal back light. You show it connect to the
nav lights as ON and OFF deal. It does seem like this from the
text, like it is a ON/half/OFF deal from the text. Again a call to ICOM
says back lighting is affected by voltage. In other words light intensity
is variable and proportional when connected to a variable voltage.
ICOM errata:
The previous post that ICOM shows the incorrect optional
switches for the Yoke mounted channel and frequency exchange
switches, I believe they have corrected it. They show spring
loaded DTSP toggle, normally in center open position and
momentary to ground pin L or 12. The optional switch choice is
two single momentary SPST switches to ground.
George
From: "Robert L. Nuckolls, III" <nuckollsr(at)cox.net>
Subject: Re: Re: Icom A200-Help!
III"
At 09:58 AM 2/12/2006 +1100, you wrote:
A real service manual! I'd love to get a copy.
The latest wiring on the ICOM website shows two normally
open, pull-downs to ground for those two functions.
I needed a break from some other things I was supposed to
be
doing today and threw a little drawing package together. It's
posted at
http://www.aeroelectric.com/Installation_Data/IC-A200_Icom_Installation_Wiring.pdf
If folks would care to review it and ask any questions that
are not
answered, suggest additional materials be added or have
spotted
errors, I'd be delighted to get he feedback. I've already found a
goof. I'd intended to show how to "dummy load" the speaker
output with an inset on page 2. I also note that the real model
number is IC-A200 which ought to be fixed in several places.
Use Photomail to share photos without annoying attachments.
