rondefly(at)rtriano.com Guest
Posted: Sat Feb 11, 2006 6:06 pm Post subject: Bosch Ice cube relay |
I have looked at the schematics on the search for these but could not
understand which pin on the relay is which, also tried to find it on the web
to no avail. There are 5 pins on it. #s 30, 85,86,87,87a. I want to use
this type of relay to control my flaps, reflexor, ailerons, they all will
have a motor that reverses if you change the pos and neg terminals. Sorry
for being so electronically dump.
http://bld01.ipowerweb.com/contentmanagement/websites/rtrianoc/page10.html
altoq(at)cebridge.net Guest
Posted: Sat Feb 11, 2006 6:37 pm Post subject: Bosch Ice cube relay |
Ron,
Remember Europeans switch everything to ground, 30 is always ground no
matter what the circuit. 85 and 86 are the armature or coil. 87 is normally
open to 30 and 87a is normally closed to 30.
John D.
DO NOT ARCHIVE
Posted: Sat Feb 11, 2006 7:21 pm Post subject: Bosch Ice cube relay |
John, thanks for the reply however do you mean if I put my ground to 30, one
lead from the motor to 85 and the other to 86, then what do I do with 87 and
87a?
Ron
sportav8r(at)aol.com Guest
Posted: Sun Feb 12, 2006 4:26 am Post subject: Bosch Ice cube relay |
Ron, you mentioned reversing a motor... can't be done with a SPDT Bosch relay. You'll need two poles, in your case that's two relays. "Armature" is the coil, the part that gets current flow through it to pull the relay closed. The common contact is, I believe, #30, and the others are the N.O. and N.C. contacts. If that's beyond what you can follow, you are definitely going to need a picture (schematuc) to look at. Ditto for the DC motor reversing concept.
-Bill B
Posted: Sun Feb 12, 2006 6:21 am Post subject: Bosch Ice cube relay |
Ron,
No, 85 and 86 are the contacts that actuate the relay, 30, 87, and 87a are
all the switch. 87a is normaly closed to 30. When voltage (12VDC) is
applied accross 85 and 86, 87a and 30 open and 87 closes to 30. Don,t try
to say that too fast. :~p For what you want to do you need two relays.
John D.
jschroeder(at)perigee.net Guest
Posted: Sun Feb 12, 2006 7:32 am Post subject: Bosch Ice cube relay |
Ron -
I have a schematic for running the flap motor of our Lancair ES. It is a
reversing scheme using two relays. It is in .pdf format. Let me know if
you want it and I'll email it to you.
Cheers,
John.
<altoq(at)cebridge.net>
Ron,
are
try
John D.
Thanks all for the replies, I will try that today. I did buy 6 of the
relays.
Ron T
Posted: Sun Feb 12, 2006 7:41 am Post subject: Bosch Ice cube relay |
John, thanks for being so patient with me, I tried it that way on the bench
and it works just like you said.
Ron T
capsteve
Joined: 09 Jan 2006 Posts: 111 Location: NIAGARA FALLS NY
Posted: Sun Feb 12, 2006 10:36 am Post subject: Bosch Ice cube relay |
Here's a neat little pdf that shows some cool relay setups. The reverse pole
stuff that would pertain to a reversing motor is on the last two pages..
Steve dinieri
http://www.tune-town.com/relays.pdf
chaztuna(at)adelphia.net Guest
Posted: Sun Feb 12, 2006 12:42 pm Post subject: Bosch Ice cube relay |
Ron
Where did you buy them. Waytek Wire has great prices on Genuine Bosch "ice cube" relays (and the mounting sockets for them). See
http://order.waytekwire.com/CGI-BIN/LANSAWEB?WEBEVENT+L0A298B332B9408002F3F051+M37+ENG
Charlie Kuss
relays.
Ron T
nuckollsr(at)cox.net Guest
Posted: Sun Feb 12, 2006 12:52 pm Post subject: Bosch Ice cube relay |
See drawings in the package at:
http://www.aeroelectric.com/PPS/Flight/Flaps/Flaps.pdf
Sheet 3 or 4 is probably what you want.
