Rotax 377 and 447 use same points and ignition?
kentk
PostPosted: Sat May 12, 2007 5:24 pm    Post subject: Rotax 377 and 447 use same points and ignition? Reply with quote
Hello,
I have a Rotax 447 motor, and noticed some 377 ignition parts for sale, would they work with the 447? I appreciate any and all advice.
Kent Knudsen
College Station, TX
K-IV 1200 / no engine / 25% done
ElleryWeld(at)aol.com
PostPosted: Sat May 12, 2007 6:00 pm    Post subject: Rotax 377 and 477 use same points and ignition? Reply with quote
If you have a California Power Systems book look up the part numbers and see if they match if you dont have one let me know and tomorrow when I get in the shop I will look up the part numbers for you to see if they match
Ellery
See what's free at http://www.aol.com. [quote][b]
kentk
PostPosted: Sat May 12, 2007 6:23 pm    Post subject: Re: Rotax 377 and 447 use same points and ignition? Reply with quote
[quote="ElleryWeld(at)aol.com"][b]If you have a California Power Systems book look up the part numbers and see if they match if you dont have one let me know and tomorrow when I get in the shop I will look up the part numbers for you to see if they match
Thanks, Ellery! I do not have a California Power Systems book. I should also add that I have corrected the subject to show Rotax 447, not 477 as previously stated.
Kent
Kent Knudsen
College Station, TX
