MAP in mmHg
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> M14PEngines-List
eddiemoranii(at)yahoo.com
PostPosted: Tue May 08, 2007 2:51 pm    Post subject: MAP in mmHg Reply with quote
I am getting about 905 mmHg on the ground here in central Florida. Ground static run while setting the prop governor.
I have a M14B with a P nose case................so does that sound about right?
To me............ it sounds bitchin.
Eddie Moran
Ahhh...imagining that irresistible "new car" smell?
Check out [url=http://us.rd.yahoo.com/evt=48245/*http://autos.yahoo.com/new_cars.html;_ylc=X3oDMTE1YW1jcXJ2BF9TAzk3MTA3MDc2BHNlYwNtYWlsdGFncwRzbGsDbmV3LWNhcnM-]new cars at Yahoo! Autos.[/url] [quote][b]
- The Matronics M14PEngines-List Email Forum -
http://www.matronics.com/Navigator?M14PEngines-List
culpspecial(at)yahoo.com
PostPosted: Tue May 08, 2007 3:33 pm    Post subject: MAP in mmHg Reply with quote
dsavarese(at)elmore.rr.co
PostPosted: Tue May 08, 2007 5:15 pm    Post subject: MAP in mmHg Reply with quote
Eddie,
What RPM are you seeing and what RPM are you setting with the prop governor? The M14P should develop about 880 MM (+,- 10) at sea level, on a standard day at WOT. 905 seems a bit high, but that could also be due to the accuracy or calibration of the manifold pressure gauge. What does the Manifold pressure gauge read with the engine shut down?
Dennis
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> M14PEngines-List All times are GMT - 8 Hours
