912f gearbox question
docyukon(at)ptcnet.net
PostPosted: Thu May 03, 2007 7:33 am    Post subject: 912f gearbox question Reply with quote
Can anyone tell me if a 912f gearbox with a gear ratio of 2.27-1 has a 22mm wide gearset or the wider 27mm gearset. I do not have the gearbox part# or serial# close at hand. Thanks Bill
Thom Riddle
PostPosted: Fri May 04, 2007 3:39 am    Post subject: 912f gearbox question Reply with quote
I believe that will depend upon whether or not you have the slipper
clutch installed. If you have not modified it since new, you should be
able to contact Rotax distributor with the serial number to see what
was originally installed in your gearbox. The only other way I know to
be sure is to remove the gearbox and measure the gear sets.
Thom in Buffalo
Thom Riddle
Buffalo, NY (9G0)
- Anonymous
