FAA Alerts had CH701 items this month.
perryrt(at)hotmail.com
PostPosted: Mon Jan 23, 2006 2:56 pm    Post subject: FAA Alerts had CH701 items this month. Reply with quote
Sorry if this is a duplicate posting, folks, but I tried posting this
several days ago and it seems to have never shown up in the digests that I
get, so I'm assuming some SPAM filter munched it somewhere.
Anyway, for those of us that aren't familiar with it, the FAA puts out a
monthly publication - titled AC43-16A, or "Aviation Maintenance Alerts".
It's a summary of feedback they're getting (either voluntarily or required
per the FAR's) from operators and mechanics in the field. This last month
(Dec 05) it had three items about the CH-701 in it. The issue can be had
from the FAA at:
http://www.faa.gov/aircraft/safety/alerts/aviation_maintenance/index.cfm
It's been somewhat unusual to see items about experimental aircraft in the
past - perhaps this is a sign of an increased focus on SLSA-type aircraft
(which is a good thing, I think.)
Anyway, the important bit is that while these reports carry NO regulatory
weight with them, it's been my experience as an A&P that things that show up
in this publication are worth keeping in mind the next time you look at an
area of the aircraft, 'cause if somebody else noticed them and was motivated
enough to send in a report on it...well, let's just say that most mechanics
aren't known for their love of paperwork.
We pass these publications around to all our guys in the shop here, and I
try to keep a binder with back issues with the "items" about the aircraft we
have here tabbed. Of the three items that I saw in this particular issue,
the prop hub crack scared me a bit (considering this prop appears to have a
history of cracking in other applications - check www.ultralightnews.ca and
search on "Warp Drive" for further), and the other two issues concerned me a
little considering they're both related to primary flight controls. I think
that if I owned or maintained a 701 (I don't, not yet), I'd keep an eye on
those areas, or possibly look at beefing up those areas a bit while
building.
Thanks -
Richard Perry, A&P/IA
mike.sinclair(at)ATT.NET
PostPosted: Mon Jan 23, 2006 5:22 pm    Post subject: FAA Alerts had CH701 items this month. Reply with quote
Richard
Appreciate you bringing the 701 safety alerts to our attention. As you (or
any other A&P's) have regular access to these type of alerts, most defintely
feel free to pass this info along to other builders. As I am limited to a dial
up connection only, I don't usually see these type of alerts, though suspect I
might try to look them up a little more. This one took over 45 minutes to
download.
Now, for what it's worth, I took a good look at the alert and my best guess
on the prop hub crack is that it is probably on an older 582 powered 701 as it
is only a 2 bladed prop. Most of the current builders if using a warp drive prop
would now have one of the newer 3 blade assemblies. On the cracked elevator
hinge bracket, this looks to be one area that should be looked at during
conditional inspection. Though looking at the condition of the paint surrounding
the area leads one to belive that this aircraft has had considerable use,
possibly been parked outside a long time, and the problem should have been
noticed quite some time ago due to the deterioration in the bend area. Finally,
the loose rudder hinge problem looks to me to be a builders error in the first
place. I have the plans dated 1986 and even in them it calls for AN3 bolts to
hold this plate in place, not pop rivits. I would suspect that a close
examination on this aircraft would find more than just the 3 problem area listed
in the alert.
That said, thanks again for passing on this info.
Mike Sinclair N701TD
from the FAA at:
building.
Thanks -
marinegunner(at)gmail.com
PostPosted: Mon Jan 23, 2006 5:40 pm    Post subject: FAA Alerts had CH701 items this month. Reply with quote
Richard,
I went to the web site you bookmarked, but could not find my way to
AC43-16A. Can you give me some additional guidance - I am very interested in
reading these safety items.
On 1/23/06, Richard T. Perry <perryrt(at)hotmail.com> wrote:
the FAA puts out a
from the FAA at:
Semper Fi,
Steven R. Hulland
CH 701, Amado, AZ
This and all other incoming/outgoing email, attachments and replies
scanned prior to opening/sending and uses an external firewall to help
lgingell
PostPosted: Mon Jan 23, 2006 7:10 pm    Post subject: Re: FAA Alerts had CH701 items this month. Reply with quote
Its the December PDF:
Look here: http://www.faa.gov/aircraft/safety/alerts/aviation_maintenance/media/2005/2005_12_Alert.pdf
hope this helps you find it,
..lance
Zodiac XL/Jab 3300
http://lancegingell.com
PostPosted: Mon Jan 23, 2006 7:29 pm    Post subject: FAA Alerts had CH701 items this month. Reply with quote
Steve
When you go to the link, and see the box with the 2006 that has the click down
button, go there and pick 2005, then Dec. And it gets you right to where you
need to go.
Mike Sinclair ex- US Navy, Just like always, gotta help the Marines get to the
beach!
Steve Hulland wrote:
Richard,
> Semper Fi,
> Steven R. Hulland
> CH 701, Amado, AZ
Steve
need to go.
Mike Sinclair ex-US Navy (and not just an average boat jockey, 2 tours to Nam
with one spent in the Delta riding river boats), & just like always, gotta help
the Marines get to the beach!
N701TD
Richard,
> Semper Fi,
> Steven R. Hulland
> CH 701, Amado, AZ
craig(at)craigandjean.com
Or as a tiny URL:
http://tinyurl.com/9ew7d
-- Craig
PostPosted: Mon Jan 23, 2006 7:45 pm    Post subject: FAA Alerts had CH701 items this month. Reply with quote
My appologies guys, didn't think the first little bit of guff for the Marines went
out. Thought I stopped it before it went because I wanted to add another line. And
Steve, I hope you didn't take any offense, it's just a small part of the crap I get
from my other ex-Marine friends. After seeing all the Semper-Fi, I finally couldn't
hold back any longer. And for sure am proud of all our Vets.
Mike Sinclair
PostPosted: Mon Jan 23, 2006 8:15 pm    Post subject: FAA Alerts had CH701 items this month. Reply with quote
Mike,
No offense taken, I am aware of the source. During my twenty plus years in
the Corps I spent more than three years afloat, 2 years teaching at
Navy/Marine Corps schools; 1.5 years as OIC of Navy/Marine Corps schools;
1/2 year stationed at NAS; and 2.5 years as Marine I&I at NAS. Rank varied
from Sergeant to Captain. In all cases, the Navy guys needed lots of help
reading/working radar/filling out personel evaluations/making decisions and
figuring out who the enemy was. On the other hand, they never needed help
with Acy-Ducy; Drinking Coffee; Finding their Rack; or Determining the best
Liberty location and time. Besides, during those few times I needed a taxi
from the boat to the beach, the Navy was there. I got to the beach via Navy
taxi (excluding numerous liberty taxi's) eight times - appreciate the rides.
BTW,
I did go to the "Display Alerts" and attempted to display December 2005 - it
did not work. Will try something else when I do not have to get some sleep
before work.
*Do Not Archive
Semper Fi,
Steven R. Hulland
CH 701, Amado, AZ
This and all other incoming/outgoing email, attachments and replies scanned
prior to opening/sending and uses an external firewall to help insure virus
n7cr(at)bellsouth.net
PostPosted: Mon Jan 23, 2006 9:12 pm    Post subject: FAA Alerts had CH701 items this month. Reply with quote
Did anyone else get the impression that this particular 701 has been poorly
maintained?
In the photos of the rudder hinge, I believe the location was identified
incorrectly in the report. That appears to be the upper rudder hinge plate
7F4-1, which as Mike correctly points out should be attached with 4 ea AN3-4A.
It is identified as the _lower_ hinge bracket in the report.
It also appears that the elevator hinge bracket described in the report is more
properly identified as the center hinge gusset 7H5-4 in the 2004 plans, which
has been changed from two L sections riveted together as shown in the photo, to
a single bracket with an additional flange which would reduce the flexing of the
gusset web which causes the stress crack at the bend.
Rory
CH-701 empennage nearly complete
Mike Sinclair said the following on 1/23/2006 7:21 PM:
<SNIP>
in the alert.
ggower_99(at)yahoo.com
PostPosted: Mon Jan 23, 2006 11:03 pm    Post subject: FAA Alerts had CH701 items this month. Reply with quote
By the way, looks like that airplane (in the article) is very negletled (sp?) is no surprise to find this problems there, also I think (almost sure) is a pre 912 model, remember that the 701 has about 25 or more years since the first plans were released...
Nothing better that a good daily preflight, personal washing the plane and constant by the book mantainance to keep a safe airplane.
What ever, if someone finds something important like this, please let us all know. I (we all) appreciate it very much. Safety first.
Saludos
Gary Gower.
maintained?
Rory
in the alert.
Ring in the New Year with Photo Calendars. Add photos, events, holidays, whatever.
cfd(at)thegateway.net
PostPosted: Tue Jan 24, 2006 8:47 am    Post subject: FAA Alerts had CH701 items this month. Reply with quote
Richard,
Good information, thanks. I believe that Zenith did change to bolts for the
upper rudder hinge attachment.
Also, somewhere I remember reading that the vibration/shaking from the
starting and stopping of the Rotax 912 can cause some problems with the
tail.
Chuck D.
N701TX
PostPosted: Fri Feb 03, 2006 10:32 pm    Post subject: FAA Alerts had CH701 items this month. Reply with quote
Reference the FAA alert:
<http://www.faa.gov/aircraft/safety/alerts/aviation_maintenance/media/2005/2005_12_Alert.pdf>
I finished assembling my 701's elevator & stabilizer tonight and noticed
something I hadn't before while the brackets were clecoed.
If you look at the photos on pages 13 and 14, notice the wear on the gusset
edge. This is caused when the elevator is at full up position and 7H5-3 horn
angle bangs against the gusset. I guess it's intended as an elevator stop?
This potential wear point could be avoided (too late in my case, since I
followed the drawings and assembly manual) if the elevator center hinge assembly
(7H3-3 and 7H5-4) is flipped 180 deg and shifted to the left to place the
centerline on the side of 7H3-3 opposite the gusset.
It might be a good idea for you fellow 701 owners to take a look at this. For me
it will be one more thing to check on the preflight.
Rory
CH701 Kit empennage completed
Lacombe, LA
Rory
jean-paul.roy4(at)tlb.sym
PostPosted: Sat Feb 04, 2006 3:20 am    Post subject: FAA Alerts had CH701 items this month. Reply with quote
Thanks Rory for the heads up. I'll certainly look into it. I'll be reaching
this point this week end.
Jean-Paul
CH 701, mounting the hor. stab
JERICKSON03E(at)aol.com
PostPosted: Sat Feb 04, 2006 7:21 pm    Post subject: FAA Alerts had CH701 items this month. Reply with quote
In a message dated 2/4/2006 12:33:33 AM Central Standard Time,
n7cr(at)bellsouth.net writes:
Sounds like the position when the AC is parked, with the stick secured in the
full back position. Perhaps secured back with the seat belt? Perhaps loosens
a little, then works in the wind?
We could be doing the damage ourselves.
Is there another, better, way to secure the elevator?
zodie(at)adelphia.net
PostPosted: Mon Feb 06, 2006 8:46 am    Post subject: FAA Alerts had CH701 items this month. Reply with quote
PostPosted: Mon Feb 06, 2006 7:01 pm    Post subject: FAA Alerts had CH701 items this month. Reply with quote
R.P. said the following on 2/6/2006 10:42 AM:
I'm not sure about the 701's elevator, but the elevator stop on my 601 is
attached to the rudder fairing and is set for full deflection of the
elevator without allowing the horn and gusset to ever contact each other.
Is the 701 different?
Rick Pitcher
N601ZR
Hi Rick, Glad to see you over here too.
Looking at the drawings it appears there is no "real" up elevator stop on the
CH-701. Down elevator is limited by the contact of the lower elevator horn
against the rear of the fuselage, as noted in the drawings to "later: file to
adjust elevator stop" (Dwg. 7H5). No mention of up elevator stop.
Rory
CH-701 working on wing skeleton
Lacombe, LA
