Any 8's with firewall mounted oil coolers out there?
edrv(at)cox.net
PostPosted: Thu Mar 29, 2007 7:30 pm    Post subject: Any 8's with firewall mounted oil coolers out there? Reply with quote
just fixed my over heating 8A, moved f/wall mounted cooler to left uper baffle. also set 1 washer in front of 32, rear#3 . temps dropped 40/50 degrees , It was 55-60 degrees during test and I was way to hot!! best of luck-- Speedy11(at)aol.com wrote:
Dennis,
I mounted my oil cooler on the firewall and, although I haven't yet flown,
I'm convinced from studying other web sites and information posted on the
internet that my setup will be successful. I have the 11 row dual pass S&W, which
is larger than other coolers, so finding room on the firewall was challenging.
I focused on providing sufficient, unobstructed airflow into and out of the
cooler.
If you'd like photos I can send them (let me know) or you can view them on my
web site at _http://www.rv-8a.net/chronology.htm_
(http://www.rv-8a.net/chronology.htm) beginning on 8 Jan 07 and ending on 30 Jan 07. The page is very
long so you'll need high speed internet to view it in a reasonable amount of
time.
If you have questions about my installation feel free to contact me at
speedy11 at aol.com. Also, after I fly I will post info on my oil temps.
Stan Sutterfield
Has anybody out there ever sucessfully mounted an oil cooler on the firewall
of an 8? If so do you have pictures? I saw one on a 6 today. Not sure if there
is room on our firewalls but if so I would sure like to do it that way rather
than on the back baffle.
Dennis Flosi
N963DF finishing kit
