Booster coil
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> M14PEngines-List
ScottA
PostPosted: Sun Feb 05, 2006 8:52 am    Post subject: Booster coil Reply with quote
My booster coil is 1940’s vintage type with no case.  It took only one wire for power (12v system) to hook it up and it is grounded through the case/mount.  Looking at pictures of others set up with the newer (relatively speaking) ones that have a case on them I see two small wires going in?  Do these with the case need an external ground wire?
Scott
- The Matronics M14PEngines-List Email Forum -
http://www.matronics.com/Navigator?M14PEngines-List
KJKimball(at)aol.com
PostPosted: Sun Feb 05, 2006 11:36 am    Post subject: Booster coil Reply with quote
Scott,
All the encased or open booster coils we have worked with require only one wire for the input voltage, 12 or 24 depending on the system.  If the coil is mounted with adel clamps or other nonconductive means, a second ground wire is required to ground the case to the airframe.  This may be what you have noticed in some photos.
KK
ScottA
PostPosted: Sun Feb 05, 2006 11:46 am    Post subject: Booster coil Reply with quote
Thanks, that is what I noticed both on a Pitts 12 and another Moose.  They both had adel clamps holding it to the engine mount..  The person who asked me will probably join this list but I didn’t want to pass on bad info.
Scott
From: owner-m14pengines-list-server(at)matronics.com [mailto:owner-m14pengines-list-server(at)matronics.com] On Behalf Of KJKimball(at)aol.com
Sent: Sunday, February 05, 2006 12:35 PM
To: m14pengines-list(at)matronics.com
Subject: Re: M14PEngines-List: Booster coil
Scott,
KK
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> M14PEngines-List All times are GMT - 8 Hours
