THANKY YOU! re:Formation flight comm atte
Fiveonepw(at)aol.com
PostPosted: Wed Jan 04, 2006 7:58 pm    Post subject: THANKY YOU! re:Formation flight comm atte Reply with quote
In a message dated 01/04/2006 4:24:17 PM Central Standard Time,
nuckollsr(at)cox.net writes:
http://www.aeroelectric.com/articles/Attenuator
Another example of why I'm a confirmed Nuckollhead- dangle a real-world
problem in front of someone who doesn't have their nose in the flight levels or up
the exit end of their alimentary canal and voila': solution! Reminds me of
when Indiana Jones (first movie- the others REALLY stank!) is confronted in some
marketplace (Algiers?) by the black-robed ninja-type dude flingin' the blade
all over the place and Indy just pulls out his revolver and solves the
problem. Quick, simple, efficient.
Just to further my education- why the 50 ohms to gnd when switched on, and
what is rationale for the fancier switch than shown in the foto? Also- any
reason not to do a TPDT switch for an annunciator light?
Thanks AGAIN Bob for another great assist and for just doing what ya do!
Also appreciate the comments and suggestions from other A-listers in the
prosecution of this problem...
From The PossumWorks in TN
Mark Phillips - RV-6A N51PW (no wallpaper but a journeyman certificate and 25
years herding robots, plcs, big automation systems etc.....)
brian-yak(at)lloyd.com
PostPosted: Wed Jan 04, 2006 8:21 pm    Post subject: THANKY YOU! re:Formation flight comm atte Reply with quote
Because that is what the transmitter wants to see. If the resistance
(impedance actually) is different from that by a factor of three or more
the transmitter could either be damaged or, if it has a protection
circuit, it could refuse to transmit.
and what is rationale for the fancier switch than shown in the foto?
It would do a better job of presenting the aforementioned 50 ohm
impedance. Regardless, at the relatively low frequencies at which VHF
comms operate, Bob's wiring looks darned good and is unlikely to cause a
problem with your radio.
Also- any reason not to do a TPDT switch for an annunciator light?
None at all.
Brian Lloyd 2243 Cattle Dr.
brian-yak at lloyd dot com Folsom, CA 95630
- Antoine de Saint-Exupery
